Big offside engine mount question
Postby Knowledge » Thu Jan 20, 2022 10:32 pm
I have not been happy with the handling of my scooter for a long time, but I think I might have found the problem.
When I dropped the engine out of the scooter yesterday I found that while the big offside engine mount was as it should be (stiff), the standard size engine mount on the near side is very floppy (by comparison).
I need to replace this NS engine mount with something stiffer. Does anyone have a recommendation?
Re: Big offside engine mount question
Postby hullygully » Fri Jan 21, 2022 1:22 pm
didnt you change both @ the same time bud?
Postby ULC Soulagent » Fri Jan 21, 2022 7:13 pm
ULC Soulagent
Postby Knowledge » Fri Jan 21, 2022 9:58 pm
hullygully wrote:didnt you change both @ the same time bud?
Yes, but the long RHS engine mount comes without a compatible LHS engine mount; you have to source your own.
Postby Knowledge » Fri Jan 21, 2022 10:01 pm
ULC Soulagent wrote:If you want stiff then try these
https://www.sip-scootershop.com/en/prod ... c_17474600
I am not sure I am in the market for the stiffest engine mount on the planet, just the one that is most compatible with the long RHS engine mount. Those ones from SIP look brutal
Postby ULC Soulagent » Fri Jan 21, 2022 10:31 pm
Yes they are brutal but good for the race track, the green version is a softer compound and I’m sure is interchangeable from right too left and visa versa. I’ll check them on one of my spare engines tomorrow and confirm.
ULC Soulagent
Postby Leotech » Sat Jan 22, 2022 4:42 pm
I tend to run a stiffer mount on the shock / gearbox side of my Lambretta to stop the mount deforming quite so much and a softer one on the other side.
Leotech
Postby ULC Soulagent » Tue Jan 25, 2022 5:57 pm
Here we go
ULC Soulagent
Postby Knowledge » Wed Jan 26, 2022 10:11 pm
That looks seriously stiff.
I have ordered a Casa item and will have a feel of it and decide whether to fit it with the BIG OS engine mount.
I bet I end up wishing I bought two Casa engine mounts and abandon the BIG mount.
Postby hullygully » Thu Jan 27, 2022 10:03 am
I've got 3 x big mounts on varying steeds, my TV's std ones used to last me 1 1/2 seasons, extended ones being in 8yrs
