My rear brake pedal wobbles side to side. It has a new burass bush, so the pin must be worn. I should have replaced it before paint/build.
Is there an easy fix?
bazza3004 wrote:would drilling and tapping the pedal post help. ive done this before then used a suitable sized bolt and flat washer screwed in to hold pedal in place but this was on a scoot where circlip groove was worn. it may help your side to side movement if the washer used is up against the pedal until you replace the post.
AlG wrote:Aren’t they supposed to have a thick and then a thin washer/shim as well? Not sure which way round they go before or after the pedal and then circlip?
dickie wrote:Google is your friend.....
https://scooterlab.uk/lambretta-brake-pedal-pin-repair-workshop/
Job for the winter.
EddieStone wrote:I did it on mine and it wasn't messy.
It's not hard but you do need to be careful and not rush it.
Users browsing this forum: Google [Bot] and 38 guests
