by Pops » Mon Sep 03, 2018 5:51 pm
Rebuilding series 3 Li 125 replacement light switch has a purple wire but there is not a purple connection on headset connector block any info as to where I can connect it
Pops
by Scooterlam » Mon Sep 03, 2018 9:31 pm
is it much longer than the others could be horn.
Scooterlam
by HxPaul » Tue Sep 04, 2018 7:48 am
Purple is usually an auxilary live feed.If its 12v and there is no puple on the loom,it goes in with the browns.
by Pops » Tue Sep 04, 2018 4:26 pm
It's not wire for horn they are already connectedthink must be auxiliary wire will plug into brown connector. Thanks for advice
Pops
by modster79 » Fri Sep 07, 2018 5:33 pm
There’s good wiring information on the main website in the workshop section, it tells you where the purple goes.
modster79
Users browsing this forum: dickie, Littlewheels and 17 guests
