Morning.
Do the series 3 cut off / shortened runners fit a series 2 ? If not who’s supplying series 2 aluminium or fibreglass?
Shane
gaz_powell wrote:S3 cut off/shortened rear runners won't fit S2.
I've seen plenty of S3 one off the shelf, but when I wanted a set for S2 I had to make them.
gaz_powell wrote:Easy answer is cut down a set of F/G ones and get Chris to edge them (what I should have done) it's an expensive route but they will look good, I was never happy with my flat sheet metal ones bent (like off the shelf S3).
Are you still after S2 panel badges in vinyl....
viewtopic.php?f=19&t=86&p=300&hilit=S2+bitsa#p300
