Page 3 of 5
Re: Fully synthetic oil versus semi synthetic oil
Posted:
Thu Oct 02, 2014 7:40 pm
by Andyf
coaster wrote:IaninDorset wrote:It is a bone of contention and many schools of thought and opinion on this issue, I did remember seeing a quite good article pointing out that a standard Lambretta or Vespa engine really wasn't designed to take synthetics as the oils are thinner and don't stick to the liners and bearings well enough on a standard engine as well enough as a good mineral oil would
coaster wrote:Andyf wrote:....is semi-synth deemed thick enough?
It has nothing to do with viscosity,
Viscosity = thickness of the oil and it doesn't make any difference to it's ability to lubricate, it gets heavily diluted by petrol after all
"thinner" v "thickness". I think I get it.
acknowledging that it doesn't make financial sense, is there any detriment to using Synthetic in a standard or mildly-tuned engine?
it may be a silly question but..............is it only composite post-mix that coats the components or is there an element of separation as the heavier/stickier particles hit the metal surfaces?
Posted:
Fri Oct 03, 2014 12:15 am
by peejay
Rich Oswald wrote:I have just ordered 20L of the Exol Lubetech Fully Synth for £76 using the discount code se001. Works out at £3.80 per litre with free postage. I think anyone will find that hard to beat for a top spec' fully synth racing oil.
hi Rich
i've looked on line to order the oil from a lubetech agent, their price is £84. 90p with free postage.
i cannot see where you can add the discount code but then i'm not the smart cookie
Posted:
Fri Oct 03, 2014 8:32 am
by mickyb
It's on the other forum!!
Posted:
Fri Oct 03, 2014 8:36 am
by peejay
mickyb wrote:It's on the other forum!!
sorry Mike, you've lost me there, i have the code just don't know where to post it
Posted:
Fri Oct 03, 2014 11:29 pm
by rossclark
I think you put it in as you check out
Posted:
Sun Oct 05, 2014 11:54 am
by mainstand
I use groundsmans as well. Get it from Sheffield posted, work out cheap as chips. Done 4,500 miles this year using the stuff with no issues. Mind you when I stripped my top end down the other day it seemed a little dry for my liking, but that maybe because I have a reed block, so no waste.
Posted:
Wed Oct 08, 2014 10:53 pm
by Rich Oswald
peejay wrote:Rich Oswald wrote:I have just ordered 20L of the Exol Lubetech Fully Synth for £76 using the discount code se001. Works out at £3.80 per litre with free postage. I think anyone will find that hard to beat for a top spec' fully synth racing oil.
hi Rich
Hi Peejay,
Just wondering about "Lubetech Agent", and why not Lubetech direct? That's maybe why there is no facility to put in the discount code. As said it comes up at checkout,
Posted:
Thu Oct 09, 2014 8:15 am
by peejay
thanks for info Rich, i'll be giving it a go soon
Posted:
Thu Oct 09, 2014 8:53 am
by gaz_powell
this is where you buy
http://www.lubetechshop.co.uk/there is discount code offered by another forum you can put in at checkout - or if you ring them they sort it out
Posted:
Thu Oct 09, 2014 6:56 pm
by Andyf
Andyf wrote:coaster wrote:Andyf wrote:....is semi-synth deemed thick enough?
there's another thread running and apparently it is definitely NOT a good idea. leads to sticky rings, and heavy sooting! among other things
Posted:
Thu Oct 09, 2014 9:25 pm
by sunrisemac
Synthetic and semi-synthetic both provide better protection at low temperature, which is when most wear is likely to occur, i.e. start up from cold, let alone the tremendous protection that is provided to high speed running engines.
IMHO, it's worth remembering what issue premix ratio is addressing, it is to keep an oil presence inside the engine during use.
For an engine that is continually used at near peak revs it will need a higher ratio of oil than an engine that is running for the majority of the time at a more modest rev range.
With that in mind, as Eden has alluded, to if an engine is not being used hard enough to burn the oil then gummed rings will probably be a consequence.
The top end of a 2 stroke engine will wear better with a good soaking of lighter oil whereas the crank and bearings which will do better with less but heavier oil, the top end is where I reckon the priority lies in the choice and ratio of oil used.
As long as the oil ratio is suitable for the use the engine is put to there is no reason to assume that synthetic or semi synthetic will gum rings and cause sooting any more than a good mineral oil.
Posted:
Fri Oct 10, 2014 10:52 pm
by rossclark
gaz_powell wrote:this is where you buy
http://www.lubetechshop.co.uk/the discount code of se001 goes in at checkout - or if you ring them they sort it out
That's a little cheeky posting their 'members' forum discount code on another site
Posted:
Sat Oct 11, 2014 11:12 pm
by Andyf
sunrisemac wrote:Synthetic and semi-synthetic both provide better protection at low temperature, which is when most wear is likely to occur, i.e. start up from cold, let alone the tremendous protection that is provided to high speed running engines.
nice one.
so, as I buy Synthetic for my tuned 225 (4%), it will be okay to put it in the standard 150 but I should stick to a lower %age?
Posted:
Sun Oct 12, 2014 7:39 pm
by sunrisemac
I can only put down my opinion and the bits I have written before are results that have been found by a lot of research on 2 stroke engines in the past by folk far more knowledgeable than me.
My experience with Lammie engines is limited to the SX150 that I have rebuilt and run in my GP it runs with fully synthetic so far at a ratio of 3% with no apparent problems, I have only done 1300 miles since I rebuilt it but it starts easily, doesn't smoke more than a trace, the plug colour is good with no oily deposits and having examined the bore with a bore scope there are no unusual visible wear marks.
However, I will be trying Groundsman semi synthetic when I run out of fully synthetic on the basis of the evidence shown provided by extensive use by other forum members
Posted:
Wed May 20, 2015 12:24 pm
by Toddy
Posted:
Wed May 20, 2015 1:00 pm
by Nelly
Just out of interest, has anybody tried this stuff from an oil supplier called Westway Lubricants.
http://www.ebay.co.uk/itm/5-Litre-2-Str ... 1c5028790eI've just ordered 5 litres, arrived within a day.
I'll give it a try at that price.
JASO FC & FD, which is what Rayspeed specify as the best to use in their advice sheets on 2 stroke oil.
Posted:
Wed May 20, 2015 1:28 pm
by Eden
It's gone up a bit. The more you buy the cheaper it is because the postage is the same on any amount. I normally buy 6 X 5 litres.
Posted:
Fri Aug 28, 2015 12:10 am
by Trojanexplosion
is it ok to use 3% oil ratio per litre with the Groundsman semi-synthetic oil or 4%
Posted:
Fri Aug 28, 2015 6:46 am
by Eden
I use 4 but only because it's cheap enough to use 4 lol
Posted:
Fri Aug 28, 2015 11:17 am
by Trojanexplosion
cheers Eden
