MickYork wrote:Cut and pasted this from a CDI supplier. I also saw the same info' on another CDI.
Key Facts
Performance CDI's advance the timing to provide a better spark at high revs
We (2-stroke lambrettas) try to retard the timing as we rev' higher, but it seems there is a different train of thought out there
MickYork wrote:so why is that not applicable to a 4 stroke engine and why do they advance the timing ?
dickie wrote:Mark, are you saying that the retard is so that the charge isn't ignited too early at higher revs? I suppose you must be. And is this because it's ineffective at converting explosive energy into kinetic energy? I guess if you ignite too early, you just try to reverse the crank, but as you've but the same quantity of fuel, more of it is converted into heat (because less has been converted to kinetic) so you increase engine temperature?
Sorry if that's a but rambling, but I'm just trying to ask in a way that works for me...if you know what I mean.
dickie wrote:Yes, it helps but doesn't actually answer what I was asking. It was a bit of a rambling question. The thing I'm trying to get my head round is while I can see why there is a need to reduce the advance (retard) to burn at the optimum moment for power, that doesn't explain why too much advance burns holes in pistons.
Or maybe it doesn't and that's just an old wife's tale?
coaster wrote:Some great tech explanation WT, I hadn't heard of the atomization issue with 2T compared to 4T, is this due to the mixture being forced around the crankcase and back up the transfers?
Users browsing this forum: No registered users and 17 guests
