Hi all,
I've got a problem with my clutch not working properly. I've installed a new clutch followed the manual (soak in oil, check clearance etc). This has been in the scooter probably about a year now . Ive only found the time to carry on with the restoration. Side case has gone back on and oil put in.
Problem is I can select gears ok but while still holding the clutch in the scooter wont roll. It locks up on the gears, also i can change gear at a standstill without pulling the clutch.?
I'm sure I followed all instructions to the manual. This was probably at the back end of last year now, would sitting for a while dry out the clutch and gearbox as its had no oil sitting in it.
I'm fearing it's a strip down again unless theres an easy fix from the cable end?
Any thoughts before I get stuck in are much appreciated.
