Re: Li 150 won't start/run
Posted: Fri Dec 24, 2021 4:10 pm
ianmoran wrote:Thanks again.
We've tried squirting eezi start in the carb but not oil in the head, so far.
I'm beginning to think it must be an electrical fault. Although the system produces a good spark outside the cylinder , what is the effect of putting the plug into the head on the functioning of the coil. We have tested 2 coils so far and they appear ok. There has been mention of a "collapsing spark" when it's under pressure in the head. Has anyone got any thoughts about this?
I've had a good spark outside the cylinder with a 12v system break down when installed into the motor and refuse to start but I have never experienced it with points etc.
Is the coil connected to the correct terminals? It says in most manuals one way is better, but from memory I cant remember which is live and which is earth.
Could the flywheel need re-magnetising?
