by Lambr62 » Tue May 24, 2022 11:01 pm
Hi,
Any advice on drilling the badge holes on the side panels. In my case to suit SX200. Templates etc?
Lambr62
by hullygully » Wed May 25, 2022 10:11 am
get the dims of someone pre painting or post blasting bud
I'd of thought the 'Lambretta' badge holes are in std posn's on series 3 but its the sx200 arrows that might cause you a problem
by lofty » Thu May 26, 2022 9:04 am
I have used the following solution in the past, takes a bit of care though..
works best for 'knuckledusters' as the shape of the panel dictates the position..
stick masking tape on the approximate positions of the holes.
put a small dab of paint on the badge pins
very carefully position them where they need to go
the paint will mark the tape in the position of the holes
measure twice, cut once etc etc..
go crazy and drill
lofty
