1955 ld
PostPosted: Thu Jul 19, 2018 7:05 pm
by Rushlewin
Just thought I would say hi
I acquired this old Ld as a basket case, I haven’t had a lambretta since about 1968 an Li150
Anyway I am nearing completion just the fiddly to do,
Really annoying that there is so little information on this model been trying to get the small trunnions that go into the gear change cables on the engine. And the correct speedo cable the ones I can get won’t fit on the engine.
And the clutch cable end on the engine
And where can I get the little oval screw that adjusts the points.
Anyway rant over.
Re: 1955 ld
PostPosted: Fri Jul 20, 2018 5:04 pm
by Jono
Hi mate
I rebuilt a load of parts into a 1958mk3 LD with the advice and parts from Scooter Surgery .
I am sure they can help.
Jono
Re: 1955 ld
PostPosted: Sun Jul 22, 2018 11:45 am
by LambrettaJourney
As well as Scooter Surgery:
SPEEDO - For the speedo, do you have a problem with the length of the cable? If yes, have you looked at these two cables. The good thing with Scooter Center is the website lists the specification of the part in a number of cases, so you can review what you need:
https://www.scooter-center.com/en/86600 ... o-on-frame
https://www.scooter-center.com/en/76741 ... tta-speedo
I’m wondering if you may have a 1957 cable which is a little longer?
TRUNNIONS - For trunnions in general, as well as searching online at Scooter Center, some useful links that I suspect you may have already seen are:
http://www.scooterrestorations.com/lamb ... -controls/
http://www.scooterrestorations.com/lamb ... allen-key/
POINTS SCREW - This may be the points screw and washer your after?
http://www.scooterrestorations.com/lamb ... int-screw/
http://www.scooterrestorations.com/lamb ... ts-washer/
Other options: If you search online for “Lambretta 150D LD Spare Parts Catalogue” – download the PDF and review the image and part number of the part you need and search online, adding "Lambretta 123456 - 123" for example, I sometimes find parts that way..
Sources and shops I buy my parts from can be found below. Sometimes I source Li parts that fit, so you don't always find the parts your looking for in the LD shop / section!
UK Shops
* star sign means that I have purchased from the source with no issues (*)
All Style Scooters (Hampshire) – http://www.allstyles-scooters.com (Based in Hampshire)
Beedspeed (UK N.E, Lincolnshire) – https://www.beedspeed.com (Online / walk in shop)
Buzz Solo Moto (Halifax) – http://www.buzzsolomoto.co.uk/ (On ebay as well) (*)
Disc Dez Scooters – http://www.discodezscooters.co.uk (Dunley, Worcestershire)
Just Lambretta (UK ) – http://www.lambrettaspareparts.com/ (Online only with limited LD stock (*) )
KBR Scooters – http://www.kbrscooters.co.uk/ (Website offline – See eBay shop)
Lambretta (UK Cambridge) – http://www.lambretta.co.uk/ (Cambridge Scooters shop) (*)
Lambretta Parts.com (eBay AKA – Resurrection Scooters) http://www.lambretta-parts-for-sale.com/ Difficult to navigate, but they do have LD parts
Lambretta Spare Parts – http://www.lambrettaspareparts.com (PO Box in London – Online only (*) )
M&H Coachworks Ltd / SP Accessories – http://www.sp-lambretta-parts.co.uk (Based in Leeds and on eBay as well) (*)
Motor Cycle Prodcuts – https://www.motorcycleproducts.co.uk/ (Web Based Only – Chelmsford, Essex. Inner tubes and spark plugs.Check your tyre tube size before ordering) (*)
Scooter Emporium (UK Essex) – http://www.scooteremporium.com/ (*)
Scootopia – (UK Somerset ) – http://www.scootopia.co.uk/ (Well priced – On ebay as well. Review costs of shop and eBay and postage). (*)
Scooter Infinity (Mainly late models – LI onwards) https://www.scooterinfinity.com
Scooter Restorations (UK Nottingham) – http://www.scooterrestorations.com/ (Based in Nottingham – Online / walk in shop) (*)
Scooter Surgery http://www.scootersurgery.co.uk/ (Hammersmith) Call or visit when open for prices and availability)
SP Lambretta (Leeds / MH Coachworks) http://www.sp-lambretta-parts.co.uk/ (*)
TASS – https://www.t-a-s-s.co.uk/ (Based in Thanet / Kent) (*)
The Scooter Republic (UK South Wales) – https://www.thescooterrepublic.co.uk (*)
Overseas Shops (Review postage costs)
Lambretta NET – http://www.lambretta.net/ (Unable to get any response via email for postage questions)
Lambretta ME (Italy) http://www.lambretta.me/
Rimini Lambretta Centre (Italy) – https://www.riminilambrettacentre.com/en/ Reliable overseas source. Well stocked and resonabley priced for some items and a little over priced for other) (*)
Saigon Scooter Centre (Saigon) – http://www.saigonscootercentre.com/
Scooter Center (Germany) – http://www.scooter-center.com/ (Good service and delivery. Reasonably priced!) (*)
SIP Scootershop – https://www.sip-scootershop.com (Italy / Germany / Austrai / Switzerland – Online shop)
Olimpia Parts (Italy) – http://www.olimpiaparts.eu/en/
OMG (Italy) http://wwwomgitalia.com/en (Fuel taps. BACS payment only – not easy to pay and long delays in email!)
Ebay Shops
http://www.living3000.co.uk/shop/search ... =searchbar (Good Ebay search listing)
https://www.ebay.co.uk/str/scootopiauk (Consider visiting shop outside eBay and check postage costs) (*)
http://stores.ebay.co.uk/Resurrection-Scooters/ (AKA LambrettaPartsForSale.com
https://www.ebay.co.uk/str/splambrettaparts (MH Coachworks – See shop above as well and review postage / costs) (*)
http://stores.ebay.co.uk/kbrscooters/ (*)
http://stores.ebay.co.uk/buzzsolomoto/ (Visit shop outside eBay) (*)
Facebook Shops & Sources
https://en-gb.facebook.com/swisstonysscooterspares/ (Online shop)
https://www.facebook.com/JBFabrication (Includes engine mount stand and wheeler / runner)
I hope that this is of some help.
Good luck!
John
Lambretta Journey
Re: 1955 ld
PostPosted: Sat Jul 28, 2018 3:10 pm
by Rushlewin
Thanks for your advice, I have tried most of these places, will keep looking,
The speedo cable is in hand and should be resolved,
How have others resolved replacing gear and clutch cables, I have no idea how this part was originally as it was all missing
When I got it.
Re: 1955 ld
PostPosted: Wed Aug 08, 2018 6:03 pm
by LambrettaJourney
Hi
Please review the following videos which may help:
Gear Cable Install and Information:
https://www.youtube.com/watch?v=ilDUIFyu_3U&t=11s
The Gear Cable video above also has the list of part numbers (But no image). If you enter a part number in a search browser (for example and add Lambretta to it - "Lambretta 07770303") you will see places that you may be able to purchase a missing part. Some of the websites also show images of all the parts I have listed that have numbers on the image that correspond to the part number you need.
Two kits (Depending on handle bar - yours should be a steel) search online for these references:
Lambretta TL13100 (This is for a steel handlebar)
Lambretta TL13105 (This is for later models with aluminium handle bars)
These kits are missing this part "Lambretta 06770304" . However, you can make one of these up by drilling a hole in a bolt that fits.
There are a number of scooter parts suppliers that also hold the complete kits in stock, which includes the inner and outer sleeve part as well, that you may want to review costs if buying and depending on what parts your missing.
Review the bar / spacers and ensure you order the correct ones, otherwise you will have an amount of "play" when moving the lever. You may need oversized ones in this area (Example - Search online for Lambretta 07770301/2)
If you still have issues securing the cable itself, you may need to look at soldering the cable onto a custom bolt you make to fit into the bronze sleeve (See video), if you cant find the part 06770304
A Clutch Cable Install and information can be found here:
https://www.youtube.com/watch?v=4UDA7bsCbUQ
I hope that this is of further help.
All the best.................
