So, I have put the correct gap on the Spark plug B7hS and I have taken the bike out for a quick drive around my area.
The following happened and I have 1 thing in mind that could be the problem though Im not expert with this and some thoughts would be great help:!
The bike was performing well, the compression seems okay and with this cold it takes maybe a bit more kicks to switch on! I was riding normally, all gears perform well, acceleration seemed fine and on hills was also performing well. After a bit It started to feel weak and was not accelerating even with the throttle open at full it felts like it was trying and trying to keep up until it switch itself off and I could not started it at all and had to push it back home.
It feels like maybe the carb is quite dirty inside and is not mixing well or old fuel is clogging it a bit?? could a dirty carburator not let the bike switch on or perform properly? (this bike was off for years and had old fuel inside which I have replaced with good Castrol 2 stroke oil and fresh fuel and it has performed well after that until what happened today! I have also replaces all outer and inner cables and spark plug and adjusted the kickstarter as it was laying flat when the bike was on) I did check and seems that I still have fuel too so I discarded that.
Any thoughts on what I should check? or whats the best way to clean a carburator?
Much appreciated !
- G
