Compression ratio LD150 1957
Postby GianfraCh » Mon Jan 18, 2021 10:41 pm
Hi people,
Whats a good compression ratio for an LD150?? Thanks!
GianfraCh
Re: Compression ratio LD150 1957
Postby Steve J » Tue Jan 19, 2021 11:57 am
From the factory, the LD150 CR is nominally 6.5:1. It's possible to skim the head and remove the head gasket to increase the CR, but as the combustion chamber is a very primitive shape, with no squish area, too high a CR could well lead to detonation of the fuel/air mixture. I'd keep it below 7.5:1, and maybe use a higher octane fuel as well.
Steve J
Postby GianfraCh » Tue Jan 19, 2021 2:36 pm
Steve J wrote:From the factory, the LD150 CR is nominally 6.5:1. It's possible to skim the head and remove the head gasket to increase the CR, but as the combustion chamber is a very primitive shape, with no squish area, too high a CR could well lead to detonation of the fuel/air mixture. I'd keep it below 7.5:1, and maybe use a higher octane fuel as well.
Perfect, Thank you Steve!
GianfraCh
Postby jbcollier » Tue Jan 19, 2021 3:10 pm
You can fit a squish head. I modified a GP/DL 125 head to fit.
jbcollier
Return to Pre 57
