Series 2 survivor
Re: Series 2 survivor
Postby dickie » Sun Aug 22, 2021 1:45 pm
Warkton Tornado No.1 wrote:
As for tyres, I might have an old Varnmo or John Bull you can have ;)
Maybe the old CEATs behind my shed are still OK?
Postby ULC Soulagent » Sun Aug 22, 2021 3:58 pm
Lovely scoot,
My S2 had just fresh loom,cables, complete wheel set and RT 195 added
ULC Soulagent
Postby nsaints » Sun Aug 22, 2021 10:32 pm
Very nice scooter, I’ll watch with interest.
Personally I’m a big fan of the RT small block kit having just done the Derby rally on one which is fitted with a 25mm PHBL and a BGM version 4
Bit concerned it wouldn’t pull the 4 8 final drive having listened to some advice, but it was fine
nsaints
Postby ToBoldlyGo » Tue Aug 24, 2021 7:28 pm
Storkfoot wrote:Tyres wise, I like the Scooter Center Michelin ACS copies. Yes, they are old tread pattern but with a three ply sidewall. They suit an original Lambretta. I can’t yet give you a full road test, having probably done less than 20 miles on mine :)
They are very good. They might look like old hat, but they don't handle like it. Probably the best tyre I've ever fitted.
ToBoldlyGo
Postby ULC Soulagent » Thu Aug 26, 2021 3:06 pm
nsaints wrote:Very nice scooter, I’ll watch with interest.
Same setup as me bar it being reedvalved ;) very happy with it
ULC Soulagent
Postby hullygully » Thu Aug 26, 2021 4:02 pm
175 / 180 thru the air box, 22/25 carb, clubman, she's gargeous :mrgreen:
Postby dickie » Fri Aug 27, 2021 11:59 am
hullygully wrote:175 / 180 thru the air box, 22/25 carb, clubman, she's gargeous :mrgreen:
Thanks. I'm really pleased with it, but it's in my mate's lockup until I sell the special I've just built (my last ever lambretta :lol: )
Initially I'm going to run it totally standard, but will probably end up with the SR kit I have, a 60/115 crank, clubman, 25phbl through a modified airbox that I also have. Nothing special, probably around 10bhp. But a lot more than a 125.
Postby dickie » Thu Oct 21, 2021 12:45 pm
bsso78 wrote:I’d leave it completely alone. There aren’t that many left like that and as soon as it’s messed with it’s just another series 2
I've decided to do this, leave it completely standard. there's a tuned RT230 in my LI series 3 bitsa if i want to go a bit quicker. And I have a spare casing that I'm going to build into a 65x62 torquey, lowish power motor with the same wiring and cable interface. That way, I can swap them in half an hour and keep this one how the good lord intended. If I ever sell it, I won't be selling with a box of parts, that will inevitably get lost; I'll sell it with the original rebuilt motor, still as a 125.
Postby dickie » Thu Oct 21, 2021 7:38 pm
We all hang on to those stupid little parts that we'll never use, but every now and then we find a use for them....
This old badge has been in a box above the workbench for years. The original badge was still on, but the pins had broken off and it was held on by some twisted fuse wire.
Happy days.
Now, I need a kickstart rubber. Can't be arsed with trying to force on some stupid old perished piece of rubber, but I don't know what colour s2 rubbers were...grey or black?
Postby vegansydney » Fri Oct 22, 2021 1:32 am
dickie wrote:Now, I need a kickstart rubber.... but I don't know what colour s2 rubbers were...grey or black?
Always black from factory. Same with center stand boots.
vegansydney
Postby dickie » Fri Oct 22, 2021 7:41 am
Thanks.
Postby dickie » Sun Oct 24, 2021 11:28 am
I need a splash plate. Does anyone have a late series 2 (same as series 3) that they'd sell? Only if it's original paint grigio alba.
Postby Storkfoot » Sun Oct 24, 2021 1:57 pm
Aren’t all series 2 splash plates different to S3?
Postby dickie » Sun Oct 24, 2021 3:15 pm
Storkfoot wrote:Aren’t all series 2 splash plates different to S3?
I think the last s2 are same as s3. They have s3 style stand fixings so it makes sense.....I think, but I'm really not confident.
Postby Storkfoot » Sun Oct 24, 2021 4:08 pm
You live and learn :D
Postby dickie » Mon Oct 25, 2021 1:35 pm
Headlamp reflector is goosed but I can't find an identical one. Does anyone know where I can find one?
There was an old reflector in my boxes of stuff that I have managed to make work but I'm not really happy with it. So it's either new identical CEV one or get it re-silvered but that's going to cost near to £100!
Are these type with notches normal? New to me, but I don't have much experience with series 2.
Postby Storkfoot » Mon Oct 25, 2021 2:40 pm
Double sided tape and silver foil it works and you can’t tell through the glass.
Postby dickie » Mon Oct 25, 2021 3:43 pm
Storkfoot wrote:Double sided tape and silver foil it works and you can’t tell through the glass.
I don't really like the idea but at a cost difference of about £99 I'll give it a whirl.
Postby dickie » Mon Nov 01, 2021 8:27 pm
I've found a couple of things when rebuilding the front hub.
First was that the spindle was way too tight in the bearings. I had to really whack it to get it out but it's straight as a die. 10 minutes with some emery cloth and it's a sliding fit.
Second is that the spacer tube is missing. Having gone through my big box of shit, I thought I'd found one, but I'm not sure that it isn't just a random piece of tube I have lying about.
Can anyone confirm the dimensions please? Mine is:
14 inside, 18 outside, 64.7mm long.
Thanks.
Postby hullygully » Tue Nov 02, 2021 11:18 am
as long as it slides onto the spindle, the main dimension is the length as it acts as a spacer between the 2 x bearings bud
Users browsing this forum: No registered users and 21 guests
