Page 3 of 5
Re: ‘67 SX 150
PostPosted: Tue Jan 11, 2022 7:46 pm
by vegansydney
TurboTrev wrote:Thanks interesting thread, will be good to see it finished, the plate is for my SX150! I will look into Tippers. Cheers.
I've sent you a message and can email you a DXF file to have one (or several) laser cut. They're cheap to make, ~$8 depending on material/thickness/quantity. I made several to mount small New York license plates to.
Sorry for the thread hijack. Please post some more photos of that SX project.
Re: ‘67 SX 150
PostPosted: Wed Jan 12, 2022 12:49 am
by Storkfoot
I got my vinyl digits from these people:
https://classictransfers.co.uk/product- ... -numerals/
My SX 150 has gone for paint but may be some time before it is back.
Re: ‘67 SX 150
PostPosted: Sat Nov 05, 2022 3:49 pm
by Storkfoot
Re: ‘67 SX 150
PostPosted: Sun Nov 06, 2022 2:59 pm
by vegansydney
More pictures please!
Re: ‘67 SX 150
PostPosted: Tue Nov 08, 2022 5:19 pm
by Storkfoot
vegansydney wrote:More pictures please!
I shall do. At the moment, there are cables and wires everywhere. I wish I could remember what loom it was too :shock:
Re: ‘67 SX 150
PostPosted: Fri Nov 11, 2022 2:34 pm
by Storkfoot
Still plenty to do but I’m in no rush.
Re: ‘67 SX 150
PostPosted: Fri Nov 11, 2022 4:36 pm
by Rich Oswald
Looks lovely Paul.
Re: ‘67 SX 150
PostPosted: Fri Nov 11, 2022 5:05 pm
by Scooterslag
Storkfoot wrote:ImageImage
Looks fantastic so far- be great to see the finished scoot 8-) Paul
Re: ‘67/‘68 SX 150
PostPosted: Fri Nov 11, 2022 6:39 pm
by Storkfoot
shane BBoys wrote:Hi.
I used the uni mag house and I had to elongate the holes in both cowls to get them to fit. I checked everything before paint so all the holes are painted!!
Cheers Shane
I dry fitted the carb, a Mikuni TM24, today. I just touches the cowling because of this issue with the Uni maghousing. I am going to have to do the same as you too :cry:
Re: ‘67 SX 150
PostPosted: Fri Nov 11, 2022 6:53 pm
by gaz_powell
another cracker Paul
PS where is that rack from ?
Re: ‘67 SX 150
PostPosted: Fri Nov 11, 2022 9:57 pm
by Storkfoot
gaz_powell wrote:another cracker Paul
I’ve had it years, Gaz. A lad got some S Type copies made. They were plastic coated. This particular one was dead cheap as the holes were drilled in the wrong place, since rectified.
I think it may be the same as this:
https://www.discodezscooters.co.uk/p/la ... exact_copy
Re: ‘67 SX 150
PostPosted: Fri Jan 27, 2023 7:19 pm
by Storkfoot
As it seems more than a bit slow on the forum at the moment, I thought I’d just give an update on where I am with this.
Well, it runs although I haven’t had it on the road yet as the cowlings have gone for paint. I was going to use the cowlings in powder coated white but the white badly clashed with the other internals being painted “new white.” I also had the extra hole in the cylinder cowling welded up (see previous issue with poorly machined Uni mag flange).
I strobed it today and did have to move the stator plate. Of the three Vape static ignitions I have set up, this is the first that I have had to adjust post strobing.
As is usual, I have had a few gremlins on the way - short circuits, flooding carb, fettling two headlight rims before deciding on the Casa one and an incorrectly positioned kick start lever.
The biggest hassle has been fitting the side panels - 3 sets of rubbers and three different panel springs. All three panel springs have been “altered” by me in some way to get a better fit. The panels actually fitted okay from day one, it’s just that the panel handles weren’t exactly level and I was getting a bit OCD about it.
Pending getting the cowlings back, I’ll check it selects all 4 gears okay.
Re: ‘67 SX 150
PostPosted: Sat Jan 28, 2023 1:27 pm
by pacemaker
Looking good. please put up a video of it running when you finish.
Re: ‘67 SX 150
PostPosted: Sat Jan 28, 2023 5:18 pm
by Storkfoot
I can’t load videos onto my hosting site, unfortunately.
Here’s another pic from today though.
Re: ‘67 SX 150
PostPosted: Mon Jan 30, 2023 2:09 am
by vegansydney
Beautiful! Keep the pictures coming please.
Re: ‘67/‘68 SX 150
PostPosted: Tue Jan 31, 2023 4:18 pm
by hullygully
Warkton Tornado No.1 wrote:The last SX's were arguably the most sorted of the SIII's with touches that were engineered to apply to the GP, & probably the rarest of the type. An expert might confirm as to where they may have been assembled, though Spain may have come into play.
Sorry if you think I'm picky, but safety is paramount. The hub bearing nuts need to be shorter if the nyloc portion is to function. I can't recall where mine were obtained, but they are readily available, though if you struggle, let me know..... :)
you should be able to source some st/steel ones with the blue nyloc that are of a std length from any stockist
Re: ‘67 SX 150
PostPosted: Tue Jan 31, 2023 4:26 pm
by hullygully
Storkfoot wrote:I can’t load videos onto my hosting site, unfortunately.
nice bud 8-)
Re: ‘67 SX 150
PostPosted: Sun Feb 05, 2023 8:03 pm
by Storkfoot
I should have the cowlings back in a few weeks. I can then start running it in. You’ll see that the Mikuni TM24 has been replaced by a PHBL25. I am going to try the Mikuni on another scooter later in the year. The spare wheel holder is the Spanish set up.
Re: ‘67 SX 150
PostPosted: Sun Feb 05, 2023 8:32 pm
by dickie
Looking excellent.
What's the top end and exhaust?
Re: ‘67 SX 150
PostPosted: Sun Feb 05, 2023 9:22 pm
by Storkfoot
Original SX150 barrel, bored to 175cc with a stage 3 Chiselspeed tune. Tutto Lambretta SX cloverleaf exhaust. The one without the mushroom.
