dscscotty wrote:Dickie! I notice you have a 30mm VHSH Flatslide, thought you were running a PHBH? Did I give you jetting details for this carb?
dscscotty wrote:pm sent
steve t wrote:Looking good dickie what do you think to that front brake
HxPaul wrote:One of these will fit a battery in it and be better than fitting a capacitor https://www.ebay.co.uk/itm/Lambretta-Se ... %7Ciid%3A1
dickie wrote:
I used mypol inner tubes as I heard they were perfect fit; they're not. Or at least they're not with these stainless split rims. Maybe the valve hole is in the wrong place? Anyway, I'll use a michelin B4 tube as they're 90°. This tube will be ok for the front on my S3.
2018-01-02_03-41-04 by richardhenderson1968
Scooterdude wrote:I’ve rebuilt a few gearboxes and tend to use the MEC selector at around £75. Not worth taking the risk with the indian shite you get for £25, Scootopia or ina bearings and your good to go.
Not being critical but is that graph from after Chiselspeed fixed your gearbox? Something not right as it should make considerably more power than it shows there.
