Scooterdude wrote:Still looking at options for a new clutch. Been slightly put off the AF cassette after reading the mixed reports on them, MB 6 plate just shy of £500 now so not an option, Readspeed 6 plate £350 a bit more bearable but just found the cam lam 6 plate at £270 looks very much like the Readspeed, anyone using one and any good?
Warkton Tornado No.1 wrote:My earlier response was with the view of how to enable a stronger clutch on a budget, & if there are no financial constraints, there are undoubtedly 'fit & forget' clutches derived from motorcycles.
If money is tight, then a clutch can be done on the cheap that can work very well.
The old, two part, 46 clutch sprocket can be disassembled to enable the clutch ears to be depressed fully. Reassembly is best done with high tensile, button head socket screws (M5 I think) in the existing, ex rivet, holes tapping into the main sprocket body. I've done several like that, though 46 - 49 tooth sprockets are obtainable ready with deep pockets for the fitting of additional plates. Again, I have used them in conversions & they have been fine. I prefer to aim to fit six plates but five, in conjunction with good springs, can work well, say in a TS1. If modifications are to be made, you may as well try & fit the most plates that don't cause drag.
Inner clutch bells are obtainable designed specifically for more plates, & it is worth shopping around.
I hope that helps a little more, as not all of us can justify substantial funds & I am aware that the excuse of "only cost a tenner" cannot always fool the other halves.....
Scooterdude wrote:Ok. I went for a new Italian deep crown wheel and find I can build it using 5 surflex 3.5 mm corks and 4 1.2 steels with the standard 3mm top plate, the problem is my mallossi springs become coil bound before i get any separation so ideally need some different but still strong or strongish springs. Any ideas?
I realise I could just bang a 5 plate kit in it but i like using what I already have lying around.
Warkton Tornado No.1 wrote:Scooterdude wrote:Ok. I went for a new Italian deep crown wheel and find I can build it using 5 surflex 3.5 mm corks and 4 1.2 steels with the standard 3mm top plate, the problem is my mallossi springs become coil bound before i get any separation so ideally need some different but still strong or strongish springs. Any ideas?
Measure the springs that you have there:
Free length
Coilbound length
Wire diameter
Number of coils (eg 6-1/2 or whatever)
Tell us on here & @ least one of us will check if there is a similar set that has a shorter coilbound length for you to try
Tony Hart wrote:Warkton Tornado No.1 wrote:Scooterdude wrote:Ok. I went for a new Italian deep crown wheel and find I can build it using 5 surflex 3.5 mm corks and 4 1.2 steels with the standard 3mm top plate, the problem is my mallossi springs become coil bound before i get any separation so ideally need some different but still strong or strongish springs. Any ideas?
Free length
Coilbound length
Wire diameter
Treat everyday as a school day - what does coilbound and coilbound length for a spring mean?
Tony
Free length
Coilbound length
Wire diameter
Free length
Coilbound length
Wire diameter
Users browsing this forum: Google [Bot] and 10 guests
