dickie wrote:I'm becoming a bit of a fan of this kind of low-spec, easy to pootle about on stuff. However, as the bike is so original, I've decided that I'm going to leave it completely standard; 125 s2, standard exhaust, 6v, points etc.
But I'm building a 62 stroke x 65 bore with clubman and 25PHBL through a drilled airbox for when I get bored.
Warkton Tornado No.1 wrote:
You'd got my interest up to:
"But I'm building a 62 stroke x 65 bore"
It all went downhill after that.....
GExS wrote:Good replies given so far.
I also like low end tunes. Any combination with a 60x115 crank, 22 Dellorto with drilled Airbox, standard exhaust. I do like using Suzuki TS185 pistons. Cheap SR Indian barrels can be reworked with porting, honing and a reprofiled head. Standard ignition set to 20 degree.
Solid Air wrote:I had this done a few months ago Duncan. Any decent rebore place should be able to do the job but it takes quite a few passes to get the bore up to size, luckily I was able to get a good price thanks to my mate trading work time, otherwise it would have cost quite a bit more.
Mark
duncan1958 wrote:Solid Air wrote:I had this done a few months ago Duncan. Any decent rebore place should be able to do the job but it takes quite a few passes to get the bore up to size, luckily I was able to get a good price thanks to my mate trading work time, otherwise it would have cost quite a bit more.
Mark
This is what I have found out.
I am in Spain and took the piston and cylinder to two engineering shops and both of them were not interested in the job for the very reasons you mentioned.
Lot of time making many passes to open up the bore.
Even pushing for any idea of cost didn't get me anywhere.
It would appear that I have a nice new piston on the shelf and it's going to be staying there.
Work out cheaper and better in the long run to get a 175/186 cylinder kit .
Shame as I was looking forward to playing around with the short cylinder .
