GT186 Jetting Advice Needed
Postby Bilko » Wed Jan 16, 2019 8:07 pm
Is anyone running a Dellorto 26mm on a GT186 with a 60X110 crank and a BGM Clubman?
I'm needing jetting advice please.
Bilko
Re: GT186 Jetting Advice Needed
Postby Solid Air » Wed Jan 16, 2019 8:56 pm
Delly PHBH?
Postby Bilko » Wed Jan 16, 2019 10:19 pm
Yes, sorry. I'll fix my post.
Bilko
Postby Cgt75b » Wed Jan 16, 2019 11:05 pm
Postby Solid Air » Wed Jan 16, 2019 11:08 pm
I think I started with a 26mm on my GT then went onto 30mm followed by Keihin but need to double check, do have a 60/110 and V4 BGM though.
What do you need to know Bilko? I'll ask my mate to pull up some old dyno charts too check the info on them if you want.
Postby Bilko » Wed Jan 16, 2019 11:18 pm
Solid Air wrote:I think I started with a 26mm on my GT then went onto 30mm followed by Keihin but need to double check, do have a 60/110 and V4 BGM though.
Just a close-ish jetting for my set up. I'm not really sure what to start with.
Cgt75b wrote:http://www.lambretta-images.com/archive/GTindex.php
IThey don't have the jetting I'm looking for.
Bilko
Postby Solid Air » Thu Jan 17, 2019 12:14 am
I can't remember accurately from memory so I'll give him a call tomorrow and get back to you.
Postby Bilko » Thu Jan 17, 2019 12:33 am
Great, thank you.
Bilko
Postby Solid Air » Thu Jan 17, 2019 8:13 pm
Here you go Bilko
Main 127.5
Pilot 50
Needle N68B
Clip 2nd from top
15% full retard using BGM stator and Agusto 6000
Hope that gets you started
Mark
Postby Bilko » Thu Jan 17, 2019 9:40 pm
Thanks, appreciate your help. Do you mind me asking about float valve and atomiser? Not sure what needle that is, Google says PWK?
I laughed. Never heard that before. Thank you!
Bilko
Postby Solid Air » Fri Jan 18, 2019 12:26 am
No problem and yes you're right about the needle oops :?
Haven't got that carb anymore but X7 needle and 300 float valve rings a bell but I couldn't be 100% certain.
The Revolution Starts at Closing Time, one of my favourite albums from the mid 80s. A bit punky in places and with a bit of a fun Madness feel - if you like that sort of thing :D
Postby Bilko » Fri Jan 18, 2019 11:19 am
Thanks.
Yes. I like it too. Added to my playlist.
Bilko
