Iron barrel or nicasil lined ali barrel?
Re: Iron barrel or nicasil lined ali barrel?
Postby HxPaul » Wed Jun 04, 2014 9:57 am
Paulnobodyimportant wrote:
HxPaul wrote:I thought that the GT kits were only made for small block engines.
Keep up HxPaul
Have a look at the link below + current issue of "Scootering."
http://www.scooterotica.co/forum/viewto ... 7&p=220196" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Wow,that looks awsome.I have a small block engine with a Casa 185 kit at the moment,but I also have a GP 200 engine case and I could be tempted with the GT 200 kit.
Postby dscscotty » Fri Jun 06, 2014 7:04 am
Having ran and tuned steel lined alloy barrels for almost 20 years I am on the side of liners/re-boreable bores as preference to nicasil. Whilst I appreciate the pro's of nicasil I have all to often seen the effects of damaged cylinders at the road side,which I'm afraid often means a journey in a recovery van. It's not a pretty sight watching the owners of nicasil lined barrels inspecting the damage after issues such as seizures as they see a piece of plating is missing from the cylinder wall. Where as iron/steel lined cylinder seem to be a little more forgiving and can often be cleaned up enough to get you going again. I know of a group 6 RB250 that runs a steel lined RB cylinder and the rider agree's that the lined cylinder offers a good advantage in that he has noticed a higher running temp on the lined barrel does not always lead to siezure as he's lined barrel has exceeded tempratures that had often led to issues on his previous nicasil lined barrel. My own theory on that is that the liner is more pliable and thus able to allow for greater piston expansion. For me lined/iron ally barrels are the best of both worlds and offer some considerable advantages over nicasil/chrome bores.
Remember the old saying "Chrome don't get you home"?
Scotty-DSC
Taken from Mitaka site (Grampians):
Plated Cylinders
Pros
Cheaper to manufacture (initially)
Lighter by about 150gm (125cc cylinder).
The plated surface is very hard and suffers almost no wear.
However the aluminium behind it is soft and “packs back” over time, resulting in an increased piston clearance, even without bore wear. This cannot properly be rectified with a larger grade of piston since the wear is not uniform and a larger grade piston will be at risk of seizure.
Can potentially run very small piston to bore clearance to give a performance advantage.
Very few engine builders, or indeed manufacturers are prepared to run so close to the edge for their customers. Almost all choose to run clearances in the order of 0.040mm, exactly the same as a linered cylinder! – Forged pistons often need even larger clearances!!
Cons
Expensive and very time consuming to re-condition – cannot be rebored.
Cannot easily be honed to remove small imperfections or damage so that even the smallest fault cannot safely be rectified.
Running an imperfect cylinder risks plating detachment and total failure with potential catastrophic collateral damage to the rest of the engine.
Linered cylinders.
Pros
Mitaka offer an economical relining service.
The initial wear can be easily corrected by honing and a larger grade piston fitted to restore the exact specification.
Extended wear or serious damage can be economically repaired by reboring.
Cons
Heavier (150gm)
Can’t think of anything else, unless you can afford a new cylinder for every race.
WHICH IS THE BEST SOLUTION FOR YOU ?
Postby amb » Sat Jun 07, 2014 8:37 pm
Been thinking of putting steel liner in my ts1 225 for some time , decided to bite the bullet and go for it . would appreciate any help /thoughts ie is piston to bore the same as nicasil lined ?, pjme say no issues with heat it runs the same temp Mmm not sure about that ,not a balls out rider like to cruise at 65/70 with cht on trailtech set at 170 for danger but dont usualy get up to this , shame all the previous posts on site have gone but hey ho we will get there ,Believe Eden is the man for steel liners . Oh yea what about running them in ,might be basic stuff for some people but we need this info building up again , Thanks in advance .
amb
Postby amb » Sat Jun 07, 2014 10:21 pm
Thanks for that Eden , Well i will give it a go and see how i go on .Any info i gather will be put on the forum good or bad but could be a while yet .
amb
Postby dscscotty » Sun Jun 08, 2014 6:42 am
With regards to lined TS barrels and road use, I can assure you they offer more advantages than cons. Cooling is more efficient than a full iron barrel, prolonged high speeds can be held without the problems sometimes incured by iron barrels. They can be re-bored should wear or damage occur. There is also now more Ts1 style or similar pistons available in size increments that are suitable for Lambretta type set-ups i:e 107x 22x16 rods so they make it relatively easy to re-bore. There has been occasionally suspicion around the hardness and suitability of some liners, however this can at times down to other issues that have led to problems relating to bore wear or similar propblems. A clubmate of mine runs a lined TS1 of which I check the bore anually and at last check at the start of the year it was still running just a tad over 4" clearance. This is after nearly 4 years hard rallying which included one solo LCGB championship winning year and more recently the LCGB LE-JOG. The only service work undertaken is an occasional degalze of the cylinder and new rings which are fitted at the start of the rally season. The owner of this scooter was very sceptical when I replaced the damaged nicasil surface with a liner but now fully appreciates the advantages and has no concerns and infact prefers them.
Scotty
Postby dscscotty » Mon Jun 09, 2014 5:50 pm
Hi Eden pm sent:
Postby Bristol Daz » Tue Jun 10, 2014 8:18 pm
It's a bit late for the Swiss adventure, but I'm seriously considering having my Monza lined, could you give me an idea of time & cost Scotty. Maybe we can get together and have a chat during the euro?
Bristol Daz
Postby dscscotty » Wed Jun 11, 2014 8:23 am
Hi Daz
Not going to Euro, however you can give us a call or pop through and I'll get the kettle on.
Postby Bristol Daz » Wed Jun 11, 2014 6:04 pm
Thanks Scotty I'll give you a call when I get back and we can discuss options
Bristol Daz
Postby speedy » Thu Jun 12, 2014 8:57 pm
I personally have been running TS1's since 1987, always with nicasil and love them. I've never had a linered cylinder as nobody has ever done me one, and that's probably the only reason. I am going to be building my Italian gp 150 0ver the coming winter with a large block motor. Now firstly I was going to do a TS1 again, but no matter how much I thought about and the possibility of different specialised set ups, it seemed silly having two bikes with the same kit at the end of the day. I thought of possibly having a piston port job, say Rapido or Mugello, but as I am also finishing off a stage 4 jet 200 ,decided against this. The Avanti seemed another option until I began following the saga of the GT 200 Big block. I have now chosen to get one at the end of the year and have a cast barrel as a second rally bike. I hope I am choosing wisely on what I've seen and read. Only time will tell. Another question is, regards Ali barrels, how do folk rate Ceramic plated Ali barrels?cheers,Speedy. :D
speedy
Postby Storkfoot » Fri May 04, 2018 4:57 pm
Having run a nicasil lined TS1 for 6 or 7 years with no issues, I am now facing getting it replated for the second time in a year. The cost is getting to me.
Whilst this is a pretty old thread, it has more or less convinced me to go steel liner. Anyone got an views or experiences that haven’t been mentioned above?
Also, what pistons are people using on steel liners please?
Postby Knowledge » Fri May 04, 2018 5:05 pm
Darren Scott will be along shortly to explain this to us all.
Postby HxPaul » Fri May 04, 2018 5:59 pm
Storkfoot wrote:Having run a nicasil lined TS1 for 6 or 7 years with no issues, I am now facing getting it replated for the second time in a year. The cost is getting to me.
If the original plating lasted at least 6 years,since that you've had it replated twice in a year,there's deffinitely something wrong,either with the plating or the place that you had it plated.
Postby Storkfoot » Fri May 04, 2018 6:02 pm
No, the plating was fine. Just user error.
Postby bike grim » Fri May 04, 2018 6:53 pm
I’m using one of Scotty’s Iron lined TS1 cylinder and whilst I am still running it in I am very impressed. It’s combined with a CST3, a 30 PHBH and a 60 stroke crank. If you do get it done (I think you should) then get Darren to do it for you. He uses a Wossner piston and puts his tune on it. I went for a touring tune. I’m using 4.45 gearing and it’s really torquey. It’s the performance of a TS1 with the advantage of cast as far as I am concerned. It’s also running very cool compared to the TS1 I swapped it for ( which is still good but is sat on the shelf) to the point that I tested my SIP sensor in boiling water last night as I thought it was faulty. It isn’t.
Postby Storkfoot » Fri May 04, 2018 9:16 pm
Thanks for that detailed reply, mate. Much appreciated.
Postby coaster » Sat May 05, 2018 12:05 am
Hmm...I could be tempted to the same with my damaged TS1 8-)
Postby dickie » Sat May 05, 2018 7:21 am
Scotty did mine with a mitaka piston from ron moss. I bought the piston port type as scotty wanted to modify himself rather than get one with windows already cut.
Postby Storkfoot » Sat May 05, 2018 9:47 am
dickie wrote:Scotty did mine with a mitaka piston from ron moss. I bought the piston port type as scotty wanted to modify himself rather than get one with windows already cut.
Thanks for that. I live near a Mitaka supplier so I should be able to get hold of the pistons quite cheaply.
Postby Fast n Furious » Mon May 07, 2018 11:11 pm
Do you run your TS1 without an air filter?
