Scooterdude wrote:In my opinion the av264 is to small for this kit. To prove the point take out your main jet and see if it revs through cleanly, mine did am now using an av268.
foremanbob wrote:Scooterdude wrote:In my opinion the av264 is to small for this kit. To prove the point take out your main jet and see if it revs through cleanly, mine did am now using an av268.
Its sorted all the way through the rev range... been running that setup for over 3 years now, doing long motorway runs to rallies. The only thing that I've had to change is the pilot from a 55 in this hot weather.. was struggling to get away from lights....
I'll bear your feedback in mind though... Chiselspeed recently dyno'd a mate RT195 and put a AV268 in it with an X7
Psychedelicropcircle wrote:Same setting as foremanbob other than an AV266 & a 55 pilot.
I holed a piston on an imola with a 264 in & have been cautious of them since!
I appreciate the reply team
ULC Soulagent wrote:Jetting
30 PHBL
New type of carb or spelling typo
Leotech wrote:ULC Soulagent wrote:Jetting
30 PHBL
Sorry it was a typo, there is a PHBL carb also though. Its the smaller bodied version, similar to the PHBH.
rossclark wrote:Scooterdude wrote:In my opinion the av264 is to small for this kit. To prove the point take out your main jet and see if it revs through cleanly, mine did am now using an av268.
Sorry if this is obvious, but, if you take out the MJ and it revs all through, are you saying you should up the atomiser size until it doesn't and then adjust the MJ / needle / clip till it does or something different?
I understood that there were certain combinations of needle / atomiser that were 'optimal', with the needle circlip providing the fine tuning, but that there might be exceptions depending on other factors. So for example AV264/X7, AV266/X13, AV268/X2, and then you tune the atomiser / needle / taper / clip position from there.
