Need a 2.5mm head gasket for a SIL 200 66mm barrel.
Been hunting online to no avail. Checked the usual suspects.
Anyone know where I`d get one?
hullygully wrote:why not use a 1 + 1.5 to get your thickness, on my gori I have to use 2 head gaskets to get my clearances as it's being top n tailed
shamrockexpress wrote:you could use 6 x .5 mm gaskets and take one off that should get you back to 2.5
Knowledge wrote:Bots, if this is a one off, then why not make your own.
Get a bit of 2.5mm thick Ali and lay an existing gasket on top and overspray with an aerosol paint (ask Birdy for a can, he has loads). When it is dry, take the old gasket off and then remove any alloy from the 2.5mm plate that is painted.
I know you know this stuff, but I put it here just in case this is news to another member.
Cgt75b wrote:https://www.lambrettaupgrades.co.uk/apps/webstore/products/show/6819783
Bofs wrote:hullygully wrote:why not use a 1 + 1.5 to get your thickness, on my gori I have to use 2 head gaskets to get my clearances as it's being top n tailed
Could do but rather have one to minimise blow-out. Yours work fine? No problems?
