Re: lambretta 290 rotax
Posted: Fri Apr 20, 2018 9:18 pm
had a slight problem , had a coolant leak somewhere in the radiator area, it then got rather hot so i had to limp home stopping every mile or so to top up coolant. stripped radiator out to find a clip was not tight enough, but after re-fitting could i get coolant through to the pump, no not even with a full radiator, so in the end i added a t piece to the bottom hose and a valve, then i filled the pump from that t using some pipe and a funnel, job done closed off the valve and all is good, i also fitted a scootronic cdi and coil, wired up to run from dc, done another 20 miles tonight thats about 300 now and ive got it booked in at chiselspeed for a dyno session in a couple of weeks time to get the fueling right and see what sort of power it kicks out.
Untitled by stephen holt, on Flickr
