Re: Max Quattrini 210 kit
Posted: Thu Mar 29, 2018 9:04 pm
martin at chiselspeed can build you a crank to what ever spec you want, top man.
http://www.ilambretta.co.uk/forum/
Raveydavey wrote:Cheers fellas.
I'm running Li150 with 47 crown wheel and 18 sprocket. Martin@CST recommended that for this particular tune and I have to say it feels spot on so far.
I'm doing the coast to coast on this bike, after that ill give you a full report. Feel free to look me up if you're there too. I had originally hoped that I'd be run in by mid April so I could get the final set up done by CST on the way up there. But given life keeps getting in the way, I doubt I'll have the miles done. We'll see. It seems mighty fine aƱyway.
Raveydavey wrote:I should also add something about performance. The fun really does start at just over 5k revs which means I've got to hit near 60 in 3rd (which it does with ease) to stay in the power when I change to 4th. Feels awesome...Major grin maker!
Although I just don't quite have the power to build speed in 4th under say 55. It's ok on absolute flat or downhill of course. Gearing is tall and the barrel very slightly tuned.
corrado wrote: Hmmm, that'll make my choice of Gori 4 speed box interesting as I want to gear it to do (in theory) over 90 in 4th (for sprinting), that means close to 50 in 1st and over 60 in 2nd ..... I think it might want to throw me off the back. All I need now is the get the ***kin* exhaust to fit.
Raveydavey wrote:corrado wrote: Hmmm, that'll make my choice of Gori 4 speed box interesting as I want to gear it to do (in theory) over 90 in 4th (for sprinting), that means close to 50 in 1st and over 60 in 2nd ..... I think it might want to throw me off the back. All I need now is the get the ***kin* exhaust to fit.
I'd expect you to have no problem hitting 90. I'm expecting to top out around 85 on this motor with this pipe CST 10 (touring/road) . The CST race pipe would let it rev more, so would be in the 90s.
corrado wrote:The fun factor will be letting the clutch out off the line at enough revs without stalling or wheelying it. 19 x 47 on the Gori gives 4.56 in 4th and it'll only need 9,000 rpm to ON PAPER hit the magic ton.
Raveydavey wrote:corrado wrote:The fun factor will be letting the clutch out off the line at enough revs without stalling or wheelying it. 19 x 47 on the Gori gives 4.56 in 4th and it'll only need 9,000 rpm to ON PAPER hit the magic ton.
WOW! Goodluck with that.
Regarding my last feedback on power: bear with me, I've never had a motor built for me before but I'm now getting used to the 'super-safe-running-in -set up'. Half to full throttle is really rich and very noticeable if I try to open it up from low revs. (It's all booked in for next Friday for final set up so looking forward to that). However to my earlier comment about needing to hit 60 to keep in the power; that turned out to be related to my hamfisted throttle action. I was giving it too much fist before the revs were high enough to handle the flow of fuel; it was effectively bogging down and therefore losing speed, so I'd need to drop back to 3rd. If I go steady and open the throttle slowly I can get in to 4th at around 55 to 57 and gently turn up the heat. So its not on to half throttle until I'm back in the power band; then it pulls really nicely. I was up to 70 today with loads left. Still running in so trying to take it easy
And finally, I was cruising along a duel carriage way today doing between 65 to 70 thinking, 'this is bloody marvelous'! Grinning from ear to ear.
Andy B.L.C. wrote:Might have to get a full time job... (OUCH!) Time being more precious than money v's a bonkers small block, not totally daft mpg (pls keep the facts coming ta!), set up might be worth compromising for YIKES...
