coaster wrote:I have an unused pattern one if its any use to you Paul?
vegansydney wrote:A friend (and mentor) of mine rebuilds these. He submitted the instructions to v2 of the Spanners Manual but I guess they got left on the cutting room floor.
Basically, grind the peened top off, replace the bearing and electroplate everything before reassembling with a high tensile button head bolt. He made a basic jig to hold everything together. I'll see if I can PM you some photos over the weekend.
dickie wrote:If you get it electroless nickel plated you could give them it in that condition.
It gets dipped (in acid?) first which removes the rust and crap and the nickel gets to all the nooks and crannies without disassembly.
I've had stuff as bad as that done.
dickie wrote:If you get it electroless nickel plated you could give them it in that condition. It gets dipped (in acid?) first which removes the rust and crap and the nickel gets to all the nooks and crannies without disassembly.
a.lo wrote:I would certainly use an original in any condition over a repop anyday. this is only for the fact I could not get the remade one to work in any circumstance,whether the ramp profile is wrong or as I suspect the spring is just not strong enough as it kept binding. put the orig. back in, problem solved. trouble is it lets the look of the scooter down as I painted the visible lever part to make it look a bit more presentable as this post shows it is not easy to refurbish
Storkfoot wrote:a.lo wrote:I would certainly use an original in any condition over a repop anyday. this is only for the fact I could not get the remade one to work in any circumstance,whether the ramp profile is wrong or as I suspect the spring is just not strong enough as it kept binding. put the orig. back in, problem solved. trouble is it lets the look of the scooter down as I painted the visible lever part to make it look a bit more presentable as this post shows it is not easy to refurbish
Now having it apart, I have come to the conclusion that you really need to do pull it apart before replating. The primary reason is that there is a proper radial needle roller thrust bearing (4th part from the left) which needs to be replaced on this one and, I’d suggest, on any that have seen substantial use, or been allowed to rust away, over the years.
coaster wrote:Is that bearing available Paul? what do the repro ones use in there?
vegansydney wrote:......... My name is not Paul either
Users browsing this forum: No registered users and 163 guests
