Disc brake actuator
Disc brake actuator
Postby Storkfoot » Fri May 22, 2020 9:09 pm
How do you separate this for plating? Is it preened over ?
Re: Disc brake actuator
Postby HxPaul » Sat May 23, 2020 8:48 am
Just sandblast it,usually theirs an i cap covering the outside and you dont even see the inside(spring side) because its inside the brake.https://www.ebay.co.uk/itm/LAMBRETTA-FR ... SwTfBcdqBn
Postby gaz_powell » Sat May 23, 2020 12:43 pm
Paul
I've never stripped one but looking at that one and the remade ones, I'd say they are press/peened over
Good luck
Gaz
Postby Warkton Tornado No.1 » Sat May 23, 2020 1:25 pm
I think that I had one apart many years ago, but cannot swear as to how, or even why :?
Because the spring is very strong (like a die spring) they need compressing in a vice with a socket/tube over the pin end. Ideally they need compressing with something that allows access to the end, so an open ended thick spanner (or two) of the right size between the vice jaw & the spring collar.
The balls are just a standard ball bearing.
Postby coaster » Sat May 23, 2020 2:26 pm
I have an unused pattern one if its any use to you Paul?
Postby vegansydney » Sat May 23, 2020 2:38 pm
A friend (and mentor) of mine rebuilds these. He submitted the instructions to v2 of the Spanners Manual but I guess they got left on the cutting room floor.
Basically, grind the peened top off, replace the bearing and electroplate everything before reassembling with a high tensile button head bolt. He made a basic jig to hold everything together. I'll see if I can PM you some photos over the weekend.
vegansydney
Postby Storkfoot » Sat May 23, 2020 2:39 pm
Prised bearings out which is just as well as they were in a bad way. Still can’t see how to separate without knocking the preen off :?
Postby Storkfoot » Sat May 23, 2020 2:42 pm
coaster wrote:I have an unused pattern one if its any use to you Paul?
Thanks, mate. I do actually have another one that a previous owner chromed. However, I’d like to save that one for another day :)
Postby Storkfoot » Sat May 23, 2020 2:43 pm
vegansydney wrote:A friend (and mentor) of mine rebuilds these. He submitted the instructions to v2 of the Spanners Manual but I guess they got left on the cutting room floor.
That would be brilliant if you could let me see what he did. Thanks, Benji ;)
Postby dickie » Sat May 23, 2020 2:57 pm
If you get it electroless nickel plated you could give them it in that condition.
It gets dipped (in acid?) first which removes the rust and crap and the nickel gets to all the nooks and crannies without disassembly.
I've had stuff as bad as that done.
Postby Storkfoot » Sat May 23, 2020 7:05 pm
dickie wrote:If you get it electroless nickel plated you could give them it in that condition.
Not a bad shout. That, as long as it gets to all the rust, new 8mm bearings and a liberal dollop of grease should get a functioning actuator.
Postby dickie » Sat May 23, 2020 8:25 pm
I prefer the idea of a button head screw for future maintenance though.
Postby vegansydney » Mon May 25, 2020 4:23 am
dickie wrote:If you get it electroless nickel plated you could give them it in that condition. It gets dipped (in acid?) first which removes the rust and crap and the nickel gets to all the nooks and crannies without disassembly.
I'm a huge fan of electroless nickel. The first thing I do after stripping down a scooter for a rebuild is send all the hardware off for electroless nickel plating. I love the consistent finish, without the watermarks associated with electroplated zinc. It also looks close to factory finish and is stupidly cheap to do. That said, due to the thrust roller bearing inside the actuator, I'd be cautious about doing it on such a critical safety component, but that's just my 2 cents.
Here's a photo I took today of a rebuilt actuator on my GP. It was rebuilt by a friend and mentor, James P. (some might remember him from the old forum). It utilizes a high-tensile button head. The actuator shaft needs to be tapped to accept the button-head. High strength threadlocker is also recommended. This particular one has been in regular use for over 10 years without any issues.
vegansydney
Postby Storkfoot » Mon May 25, 2020 9:22 am
Thanks, Benji. I’ll do that.
Postby Storkfoot » Sun Jun 07, 2020 3:53 pm
If anyone has any rusty old actuators sat in their shed, I am interested in buying them. Please get in touch if you do.
Postby a.lo » Mon Jun 08, 2020 3:13 pm
I would certainly use an original in any condition over a repop anyday. this is only for the fact I could not get the remade one to work in any circumstance,whether the ramp profile is wrong or as I suspect the spring is just not strong enough as it kept binding. put the orig. back in, problem solved. trouble is it lets the look of the scooter down as I painted the visible lever part to make it look a bit more presentable as this post shows it is not easy to refurbish
a.lo
Postby Storkfoot » Mon Jun 08, 2020 5:04 pm
a.lo wrote:I would certainly use an original in any condition over a repop anyday. this is only for the fact I could not get the remade one to work in any circumstance,whether the ramp profile is wrong or as I suspect the spring is just not strong enough as it kept binding. put the orig. back in, problem solved. trouble is it lets the look of the scooter down as I painted the visible lever part to make it look a bit more presentable as this post shows it is not easy to refurbish
Now having it apart, I have come to the conclusion that you really need to do pull it apart before replating. The primary reason is that there is a proper radial needle roller thrust bearing (4th part from the left) which needs to be replaced on this one and, I’d suggest, on any that have seen substantial use, or been allowed to rust away, over the years.
Postby coaster » Mon Jun 08, 2020 5:44 pm
Is that bearing available Paul? what do the repro ones use in there?
Postby vegansydney » Tue Jun 09, 2020 12:15 am
coaster wrote:Is that bearing available Paul? what do the repro ones use in there?
They're widely available as they're common to Japanese motorcycle clutches. The Suzuki part number is 09263-15003 and the Yamaha part number is 93340-21505. As for the remade actuators, no idea, I've never owned one. My name is not Paul either :lol:
vegansydney
Postby coaster » Tue Jun 09, 2020 9:21 am
vegansydney wrote:......... My name is not Paul either :lol:
I was replying to Paul (Storkfoot), great detailed info btw 8-)
Users browsing this forum: Baidu [Spider] and 22 guests
