STRATOS DUCATI ENERGIA ELECTRONIC IGNITION SYSTEM
Postby Simon_T » Sun Apr 14, 2019 5:49 pm
Hi folks,
Does anyone run a stratos Ducati energia electronic ignition system...?
Followed the Italian instructions to the best of my ability and I don't think it was that hard to work out.
Heres the low down ive used the metal template you get with it to set the timing to 21 degrees and its meant to have a 3 and half degree built in retard , however ive used the piston stop method and marked up the mag housing using the conventional method with timing disc. Started it up and fires up great however when I strobed it, It came out like it was running at more like 23 degrees so adjusted the stator and its showing up at about 17 degrees but with very little retardation if I'm making sense.
any thoughts please.
Simon_T
Users browsing this forum: No registered users and 3 guests
