What to do with this TV175 engine?
Re: What to do with this TV175 engine?
Postby Adam_Winstone » Tue Jul 29, 2025 10:58 pm
TrackTen wrote:
Adam_Winstone wrote:^... lol... next Spring.
I'm laughing as I'm in the same scenario re: the 150cc Jap reed converted motor that I put together a couple of months back. I then found that the intended frame needed work, which has very much put this on the back burner.
Funnily enough, it's the first time that I've used a 48 rear sprocket too, which I picked up from a pal.
Cheers for now.
Adam
PS - The reed 150cc is a change for me as I tend to always go bigger but just fancied using up some of my parts that were lying about. Like the V*spa T5, it occurred to me that size doesn't always matter.... does it?
Sorry to go off topic a bit but have you posted any info on you jap reed 150 anywhere Adam ?
No, nothing yet as I want to test it first. The proof of the pudding... etc.
I have documented the build so can share it in the future but want to put the theory to the test... before spouting off (lol).
Adam
Postby TrackTen » Wed Jul 30, 2025 9:55 am
Cheers for now.
Adam
Adam
Thanks but thats not very 2025 is it - I think the modern way is you draw something , make some, sell loads and we can all see if it works after ?
But seriously - watching with interest
TrackTen
Postby Adam_Winstone » Wed Jul 30, 2025 10:05 am
^... LOL, very true.
Postby Peterp » Wed Aug 27, 2025 12:39 pm
Hello,
You’re going to wonder where this character has emerged from, I’ve only just returned to scootering after many and become a member of LCGB.
What did happen to this engine???
Just bought a TV175, few bits that need attention but nothing major. However, the only thing that is bothering me is that I obviously took my eye off the ball when buying, looking closer I think there has been an engine change, and an older engine, possibly a series 2..
I now have this thing in my head that I need to bring it back and find an engine series 3 closer to the chassis number, is this really necessary.
Am I being silly and worrying unnecessarily, it runs like a dream, I really hope I am.
Pete
Peterp
Postby Storkfoot » Wed Aug 27, 2025 1:21 pm
Peterp wrote:Hello,
Pete
It’s still on the bench. I’m in no rush.
Postby Storkfoot » Fri Jun 19, 2026 5:30 pm
Finally, I shall be putting this 185 engine in my SX150, replacing the Casa 192 that is in there at present. Unfortunately, I cannot find the Mikuni TM24 I was planning to use so, for now, I’m going to use the PHBL25 I had been using on the Casa.
I’m going to try the bgm Clubman, the enlarged MB airbox and metal mesh filter, and a SIP Vape static at 17 degrees.
The jetting I had on the Casa won’t work on this set up.
I’m thinking of starting with the following:
Pilot 48
Slide 45
Atomiser AQ266
Needle d22 2nd clip
Main 98
I know I have a d26 and a 40 slide I could try and I hope I have an AQ264 too.
If anyone has any thoughts on the jetting for an untuned 185 breathing through this air box and exhaust, feel free to share :)
Postby Storkfoot » Wed Jun 24, 2026 11:24 am
I have the engine in the frame and have swapped over the Vape ignition from the old engine. Unfortunately, I can’t find my trusty old CamLam timing disc so I am awaiting another to arrive later today. In the meantime, I think I need to lap the flywheel with the crank judging by the rust evident in the flywheel keyway :shock:
Postby Storkfoot » Thu Jun 25, 2026 1:02 pm
:roll:
Postby Storkfoot » Tue Jun 30, 2026 6:54 pm
I didn’t fully torque up the flywheel before strobing the timing. That resulted in the woodruff key shearing off. The first time this has ever happened to me.
Anyway, now I have a functional clutch, I have trundled around the estate a few times and the carb settings seem ok. On the stand too, the engine revs up and down easily. But, I do need to run this barrel in so need to do a few plug chops too.
Postby gaz_powell » Wed Jul 01, 2026 10:33 pm
Oops...
Postby Storkfoot » Fri Jul 10, 2026 7:35 pm
I managed to spend a couple of hours on this today. I’d like to say I made progress but, in reality, whilst I learnt more about the engine, I’m going to have to strip the gearbox out again I think. Having changed the gear change housing (the previous one was the original SX one from ‘68, I suspect) I now can’t get the scooter into 4th gear :roll:
Despite this, I am pretty certain that I have decided that the MB/bgm Clubman isn’t well suited to the engine. I am almost certain I shall replace this with a mushroomless standard Tutto exhaust I have.
Also, the sprockets are a 48 rear on a 15 front. It’s quite hard to kick over even with an SX200 kickstart lever. If I go back to the standard exhaust I’ll probably revert to 46/15 and a 4.8 final drive.
