drive train
drive train
Postby blumanc » Thu Nov 12, 2026 10:35 pm
currently rebuilding a series 2 125 ,186kit, clubman pipe, 22mm carb , the crown wheel is the sprung type, so I am replacing that any other modifications recommended in the gearing/drive train dept
blumanc
Re: drive train
Postby gaz_powell » Fri Nov 13, 2026 11:02 pm
I've just build a Scootopia 185, with 26mm phbh and scootopia clubman
Used a MEC crown, front sprocket and chain.
Genuine SIL spider and bell.
Standard bronze bush... Not brass
4 plate Surflex B clutch plates, AF GT springs.
Genuine SIL drive parts
Scooter Restorations nylon top chain guide and trimmed lower guide.
INA bearings on cluster and layshaft
Make sure to shim the gearbox correctly and align chain.
All good quality at good price, fitted first time no issues.
Clutch easily copes, and is nice in operation.
Lovely to ride but a bit slow.... So coming out soon
Same set up in my TS1s... No issues
Re: drive train
Postby blumanc » Sat Nov 14, 2026 10:50 am
thanks for that, did you stick with the standard ratios ?
blumanc
Re: drive train
Postby gaz_powell » Sun Nov 15, 2026 11:13 am
Yes on 185, Italian LI 150 with standard sprockets 15*46, as using a box pipe
Users browsing this forum: No registered users and 32 guests
