Recognise this noise - NOW WITH VIDEO AND SOUND (page 3)
Hi everybody
Newbie here - just finished building LI 150 with an Engine that had been totally rebuilt by somebody else!
Problem is that when running there is a noise coming from chaincase side as if something was catching - i have checked kickstart shaft (genuine Scootopia) no marks and shimmed correctly and sits on ramp in OK position.
I was wondering if gearbox shimming could be area of concern and if there was anyway I can check before starting to strip down and checking measurements ,. (pulling clutch in makes no difference)
Noise does seem to increase proportionally as you twist throttle but not 100% constant if you can understand that ???
any suggestions or help please before I start to strip her down would be greatly appreciated - THANKS
