lambretta gear size:
Can anyone confirm the correct size for 3rd gear on an LI125 early.
Sticky lists it as 39 tooth at 97.2mm
I had trouble with this meshing a while ago, and gave up, it looked visibly too small and although the measurements checked out I gave up and swapped the gearbox and stuck this one in a box of spares.
I have just stripped another engine, with an early 125 box and the 3rd gear is 39 tooth but measures 100.3mm
All other gears measure and match with the listing.
I have no reason to believe this one has been messed with, and wondered if that is the correct size for the 3rd gear.
Shaun.
Shaun.
