S2 headset space
PostPosted: Fri Dec 28, 2018 11:28 pm
by Stesjh
Looking for a bit of advice. Currently building a S2 and have noted there is limited space in the headset for additional cables and wiring. Try to add hydraulic cable and wiring plus thumb choke. Is it me or is there a lot less space compared say to a GP? Any solutions would be most welcomed.
Re: S2 headset space
PostPosted: Fri Dec 28, 2018 11:32 pm
by CHRIS in MARGATE
Removing the front brake cable will help.
PostPosted: Sat Dec 29, 2018 9:58 am
by Norrie Bodge
Loads of room
I run hydraulic/thumb choke/CHT & Rev counters
PostPosted: Wed Jan 02, 2019 4:20 pm
by Stesjh
Norrie Bodge wrote:Loads of room
Did you have to modify anything?
PostPosted: Thu Jan 03, 2019 7:20 am
by Toddy
I run similar to Norrie heres how ,
Thumb choke runs through Hole in the headset bottom along side the hgeadset clamp bolt
Clutch cable normal route
Hydralic disc cable comes up at the Front of the headset with a small fettle to allow movement
Wiring loom and extras come up the side of the gear wheels
i also have an ignition in mine as well
Hope this helps Toddy
PostPosted: Thu Jan 03, 2019 8:50 pm
by shane BBoys
Toddy wrote:I run similar to Norrie heres how ,
Paul do you have a couple of photos as they may come in handy for my ongoing project?
Cheers Shane
PostPosted: Thu Jan 03, 2019 11:45 pm
by Toddy
Cheers Shane[/quote]
Here you go buddy not finished yet but shows what you need
PostPosted: Sun Jan 06, 2019 5:26 pm
by Stesjh
Many thanks for the pictures, very helpful
PostPosted: Mon Jan 07, 2019 8:01 am
by Norrie Bodge
heres mine they may help
PostPosted: Mon Jan 07, 2019 10:15 am
by Tractorman
You will make more room if you remove the wiring junction block.
PostPosted: Mon Jan 07, 2019 10:18 am
by Toddy
Tractorman wrote:You will make more room if you remove the wiring junction block.
Agreed I’ve had to do that to fit my jockeys headlight
PostPosted: Mon Jan 07, 2019 1:47 pm
by foremanbob
Stesjh wrote:Looking for a bit of advice. Currently building a S2 and have noted there is limited space in the headset for additional cables and wiring. Try to add hydraulic cable and wiring plus thumb choke. Is it me or is there a lot less space compared say to a GP? Any solutions would be most welcomed.
How about going left field and fitting a remote hydraulic master... can thoroughly recommend the Oiltek unit that mounts under the floor on the LHS of the scoot.
Lovely bit of kit
