Rear Shocker slight leak re MOT
PostPosted: Tue Feb 19, 2019 5:25 pm
by St George
Will moisture around the chrome shaft fail the MOT Test or will it be an advisory, thanks.
Re: Rear Shocker slight leak re MOT
PostPosted: Tue Feb 19, 2019 5:50 pm
by Digger
As long as it's not oil you should be ok. Usually get that on my Bandit as it seldom gets used over winter and as luck would have it MOT is due.
My tester just wipes it off.
PostPosted: Tue Feb 19, 2019 9:53 pm
by citydaz
Why would they remove the sidepanel to see this?
my MOT tester has never removed a sidepanel.
PostPosted: Wed Feb 20, 2019 12:34 am
by Fast n Furious
citydaz wrote:Why would they remove the sidepanel to see this?
Engine mountings, Rear suspension and Rear wheel assembly are all part of the MOT check. A lot easier to do with the panels off.
PostPosted: Wed Feb 20, 2019 12:09 pm
by missing lynx
My mot-er never removes my side panels as long as you take your v5 along for the frame number mind you this is why it pays to use the same mot station so they get to know you
