Hub removal
While I've got my engine out for a spring clean I decided to investigate a problem I've been having intermittently when moving the bike backwards the wheel jams sometimes. It does not show any sign of this with the engine out - the hub spins freely in both directions with maybe just the slightest hint that it's rubbing a shoe.
Anyway I put the puller on the hub and started to tighten it down, once it got a bit tight I give the bolt a sharp tap as usual expecting that to break the taper and the hub to pop off - it was having none of it. I had to jack it the whole way off with the puller and it was tight to the last moment. I've never had this before.
The cone was still firmly in the hub and I can only presume that it was so tight in that it was dragging on the splines the whole way. I do remember that I lapped in this cone with grinding paste when it was originally fitted. It was cleaned with brake cleaner before being fitted though.
Thoughts -
a) On the backwards binding ?
b) On the hub tightness?
Thoughts -
