Page 1 of 2
fast flow petrol tap
Posted:
Tue Mar 26, 2019 5:09 pm
by kennystag
Hi All,
Can any body recommend a good fast flowing petrol tap @ a fare price.
Stag
Re: fast flow petrol tap
Posted:
Tue Mar 26, 2019 5:11 pm
by kennystag
Sorry forgot to say a 1963 mk3 LI.
Stag
Hi All,
Stag
Posted:
Tue Mar 26, 2019 6:22 pm
by gaz_powell
Ive only used genuine OMG and Scootopia
OMG gives you bottom or back outlet - never had an issue with either
Scootopia bottom outlet smaller body and original look - had a problem with the rubber washer distorting but been okay since they replaced it
Posted:
Tue Mar 26, 2019 6:41 pm
by Scooterdude
OMG from AF Rayspeed, comes with a new petrol arm that you don’t need but can then sell on. And then get a metal front piece for it from Lambretta upgrades as the standard plastic ones tend to break.
Posted:
Tue Mar 26, 2019 8:18 pm
by Toddy
Agree , OMG on mine not had any issues
Posted:
Tue Mar 26, 2019 11:13 pm
by Warkton Tornado No.1
Scootopia are the most original looking in comparison with what would have been fitted in 1963, but you should dismantle them to ensure that they have been assembled correctly.
The one I bought was fine, whilst a mate's needed the rubber membrane taking out & reassembling. (I've always done that whatever the make TBH!) They flow as fast as OMG & are so compact that they are universal in their application.
Posted:
Tue Mar 26, 2019 11:16 pm
by ToBoldlyGo
If you have trouble fitting a tap and find the silent block interferes with it the Scootopia tap is a way around it. It sits higher up and gives you that little bit more clearance.
Posted:
Wed Mar 27, 2019 9:53 am
by HxPaul
ToBoldlyGo wrote:If you have trouble fitting a tap and find the silent block interferes with it the Scootopia tap is a way around it. It sits higher up and gives you that little bit more clearance.
Plus they have a reserve that is an equal flow to the normal flow(most dont)and they are switched on as normal,but with a reasuring "click".
Posted:
Wed Mar 27, 2019 7:58 pm
by ToBoldlyGo
HxPaul wrote:ToBoldlyGo wrote:If you have trouble fitting a tap and find the silent block interferes with it the Scootopia tap is a way around it. It sits higher up and gives you that little bit more clearance.
Hah! Don't talk about reserve. You don't get a lot, so be aware.
Posted:
Wed Mar 27, 2019 8:50 pm
by gaz_powell
Yep - I've extended 3 scootopia pipes to increase the reserve as they are on TS1s
Posted:
Thu Mar 28, 2019 9:41 am
by HxPaul
gaz_powell wrote:Yep - I've extended 3 scootopia pipes to increase the reserve as they are on TS1s
But you have to alter the reserve pipe on OMG fast flow taps because there to long.
Posted:
Thu Mar 28, 2019 10:56 am
by Scooterdude
1/3rd of a litre reserve on the Scootopia tap on a standard tank so be careful. Likewise the reserve is far to great on the OMG fast flow but piece of piss to shorten, or in the case of the Scootopia add a short length of tube to the brass pipe.
Posted:
Thu Mar 28, 2019 10:06 pm
by SmallWheels
I bought a Scootopia tap last week and after fitting it I noticed that the fuel still flowed when the tap was switched off. Also, the fuel flow when the tap was open was dismal. It turned out that the rubber seal did not line up with the holes in the tap. Also, the thread in either the tap or nut was wonky so it hit the engine mount when it was tightened up. However, once sorted out it seems to work well and much better than the OMG tap which doesn’t seem to fit with wide engine mounts. Also, before you fit the tap try and blow through it and it should not be possible in the closed position. If you can blow then the rubber seal is probably not in the correct place.
Posted:
Fri Mar 29, 2019 6:03 pm
by gaz_powell
HxPaul wrote:gaz_powell wrote:Yep - I've extended 3 scootopia pipes to increase the reserve as they are on TS1s
From my personal perspective I've never bothered reducing an OMG, riding fast motorway mileage on TS1s, which aren't particularly great on fuel, Id rather have an enlarged reserve than reduced... Modifying the scootopia is essential as can be seen by the comments.
Unfortunately there are a few comments about the Scootopia assembly and components.
For future I'd be likely to go OMG again.
G
Posted:
Sat Mar 30, 2019 1:40 am
by rossclark
I got a Scootopia tap, out of the box the fuel flow was dismal - after I'd added 4l of fuel it took more than half an hour to empty the tank. On dismantling the tap the rubber was well out of line and blocking the holes. That sorted, it was flowing half a litre in about 50s.
On later reason to disconnect the fuel pipe I found that even on off the fuel flowed, again I had to drain the tank, dismantle the tap and this time I found the centre hole of the three in the rubber had distorted and the rubber lip had split. Paring the lip of that hole with a blade and reassembling it seems to have fixed it but my confidence in these taps is low.
Posted:
Sat Mar 30, 2019 8:42 am
by HxPaul
rossclark wrote:I got a Scootopia tap, out of the box the fuel flow was dismal - after I'd added 4l of fuel it took more than half an hour to empty the tank. On dismantling the tap the rubber was well out of line and blocking the holes. That sorted, it was flowing half a litre in about 50s.
I've never had trouble with a Scootopia fast flow tap.Reading all the trouble that people have had-I think I must be lucky,all I've had to do is extend the reserve and thats all.
Posted:
Sat Mar 30, 2019 10:02 pm
by Fast n Furious
I think there are some fakes around.
I had one where the rubber gasket swelled up and distorted really badly and very quickly once subjected to petrol. (probably a fleabay purchase
I made a new gasket from Nitrile rubber sheet, cleared the drillings out, then it worked fine.
Posted:
Sun Mar 31, 2019 12:00 am
by rossclark
Mine came from a dealer in Scootopia packaging - no reason to believe it was a fake.
Posted:
Sun Mar 31, 2019 9:55 am
by Hat
I got one and when i dissasembled it to make sure the rubber gasket was ok, the circlip turned out to be bent and fell off. Tested it on a spare tank and flow seemed ok, i do like the positive click for the tap positions.
Posted:
Sun Mar 31, 2019 10:45 pm
by rossclark
I've ripped it out again as it's still leaking in the off position
