extra long engine bolt
Posted:
Sun Mar 31, 2019 5:01 pm
by kdodd
anyone know of an extra long engine mount bolt, need 350-355 long as got rear disc bracket
many thanks
Re: extra long engine bolt
Posted:
Sun Mar 31, 2019 6:41 pm
by piskie
Let me know your address I will send you one
Andy vass
Posted:
Mon Apr 01, 2019 7:27 pm
by kdodd
pm sent thanks
Posted:
Tue Apr 02, 2019 10:24 pm
by piskie
Let me know where to send it foc
Posted:
Sat Apr 06, 2019 4:37 pm
by Knowledge
Are you sure you want to connect the rear disc bracket to the engine bolt?
Unless you have some sort of “give” in the disc arm, then you will put the arm under a lot of strain when the suspension compresses.
It would be better to fit the disc support arm to the outside of the engine mount, as this rotates around the engine bolt. A exhaust clamp makes a good fixing to the outside of the engine mount.
Posted:
Fri Apr 12, 2019 11:21 am
by piskie
Sent long bolt hope you received ok if u need any more or extra nuts let me know
Posted:
Fri Apr 12, 2019 10:26 pm
by Fast n Furious
Knowledge wrote:Are you sure you want to connect the rear disc bracket to the engine bolt?
I suspect the extra long engine bolt is used on the type of radius arms which have a bearing around the engine bolt fulcrum. This type is supposed to resist the rear wheel torque twist on the engine mounts which you don't get with the outer engine mount types.
