HELP plse fitting S3 stainless legshield trim
Posted:
Sun Aug 31, 2014 11:21 am
by Dobo
Hi guys, without too much fore thought I purchased some legshield trims. On receipt I realised that fitting was not going to be that straightforward!? I removed the legshield rubber edge beading and offered up the stainless trim . . . no that isn't going to be easy! There has to be a trick or two to aid fitting, so those who have done it PLEASE, please your advise will be much appreciated. Thanks in anticipation. Ian.
Re: HELP plse fitting S3 stainless legshield trim
Posted:
Sun Aug 31, 2014 11:28 am
by Jazzy b
I put some double leg shield trim on my s2 Paul at scooter restorations gave me a old pair of leggys to fit and get the shape you can put cling film round the leggys fit the top get a mate to help you he holds top while u slowly push it on all the wAy down then pull bling film out or you can cover on grease hope this helps but it is a b..stard of a job
Posted:
Mon Sep 01, 2014 9:33 am
by phil23fair
I thought you had to cut the lip off your legshields to make stainless trim fit
Posted:
Mon Sep 01, 2014 3:45 pm
by Jazzy b
I've heard that but dident need to with mine
Posted:
Mon Sep 01, 2014 5:20 pm
by Rich Oswald
No don't cut the lip off as you will never be able to go back to rubber trim. I used cling film and lots of grease on my S1, horrible job but have patience and you will get there. One side went on easily for me but the other side was a right pig,
Posted:
Tue Sep 02, 2014 9:31 am
by Dobo
OK thanks for the info so far guys. There seems to be some consistency with 'clingfilm' and grease . . . but what's this 'leggys' mentioned by you Jaz? Is that some old rubber edging or what? All HELP appreciated. Ian.
Posted:
Tue Sep 02, 2014 11:17 am
by shep65
'legshields'.
Posted:
Tue Sep 02, 2014 4:31 pm
by Jazzy b
Sorry m8 leggys are legshields the old pair allowed me to get them in to shape as mine were painted
Posted:
Tue Sep 02, 2014 5:14 pm
by Donnie
phil23fair wrote:I thought you had to cut the lip off your legshields to make stainless trim fit
you will if you bought vietnamese stainless trim for sure, and then your legshields are ruined.
