side panel buffers
PostPosted: Wed Aug 07, 2019 3:51 pm
by gazzar15
Wanting to fit my side panels but currently looking on the best way to fit the rubbers and clips....had a couple of go's and it is indeed a pig of a job !!
Re: side panel buffers
PostPosted: Wed Aug 07, 2019 5:33 pm
by dickie
On s1 or s2, some oil, grease, spit will lubricate it enough to slide on easily.
If you've got s3, and have bought "quality stainless clips", bun them and find some original ones. They're about 25% too small.
PostPosted: Thu Aug 08, 2019 1:32 pm
by burnside
S1 or S2 just stick them in a mug of boiling water for 5 mins, should go on easily enough without the need to extra lube.
S3, unless you are really being picky about looks underneath your panels, cable tie them on?
PostPosted: Thu Aug 08, 2019 1:58 pm
by HxPaul
s3 panel buffers,I just open them with a flat bladed screwdriver and push them on.
https://www.ebay.co.uk/itm/Lambretta-Si ... SwQJhUlJHI
s1 and s2 there easiest if you put them on back to front and turn them once there on.
