My engine won't come out HELP.
PostPosted: Sat Sep 21, 2019 3:18 pm
by St George
Series three LI 150 fitted to a SIL Frame. I want to take the engine out and the engine mounting seems to be corroded to the silent blocks. I have left the garage just in case I pick up a hammer and cause catastrophic damage. Top tips please.
Re: My engine won't come out HELP.
PostPosted: Sat Sep 21, 2019 4:03 pm
by jonno
Cone dislodged,does it move at all ?
PostPosted: Sat Sep 21, 2019 4:30 pm
by St George
I put some spacers inside the nut and wound it back on, it acted like a puller and is drawing it out gradually, think I am getting there. Need to order new cones as they are not too expensive but don't know which ones. There appear to be two types. Thanks for reply.
PostPosted: Sat Sep 21, 2019 11:01 pm
by ToBoldlyGo
You can use either type, dependent of what mounts you have fitted. The earlier cone is completely conical, whereas the later SX type with the larger engine mounts has a cone with a shoulder on. Or the edge taken off, whichever way you look at it. I can't imagine why you might want to fit the earlier type as the later mounts are probably preferable.
