Series 1 Crankshaft Bearing Qusetion
Morning all,
Just a quick question regarding the early Series 1 Crankshaft and mag bearing. I have removed the original mag-housing & bearing and replaced it with the 'normal' type and also fitted a new bearing, spacer ring and seals.
Are there any differences between the early Series 1 Crankshafts and the later standard LI Cranks?
The reason for asking is, I had assembled the mag housing in the following, correct order; outer seal, seal retainer plate, bearing, spacer ring, inner seal and circlip. When I refitted the mag-housing and flywheel, there was alot of play, even after tightening the flywheel nut. Thinking I'd got the order of parts wrong, I stripped the housing and refitted the parts in this order; outer seal, seal retainer plate, spacer ring, inner seal and circlip. This has sorted the play out, but is it right?
The engine will receive a proper rebuild in the future, but I just wanted to get it running, hence the seal and bearing replacement.
The only other thought I had was, should I have fitted the wider GP bearing?
Anyway, just thought I'd ask as I'm curious.
Jim
Jim
