Rear hub stud thread
PostPosted: Tue Nov 26, 2019 10:26 pm
by puggie6653
Hi All, can anyone tell me the dia and pitch of a rear hub stud hole on a Lammy , as I want to buy a tap / die Cheers TIA
Re: Rear hub stud thread
PostPosted: Wed Nov 27, 2019 7:03 am
by Toddy
Moved into here you should get a better respone
Cheers Toddy
PostPosted: Wed Nov 27, 2019 10:08 am
by HxPaul
Remember its a left hand thread.What I've done in the past when a threads gone is to put in an ordinary m8 bolt and use the nut off the original stud.
PostPosted: Wed Nov 27, 2019 10:24 am
by Toddy
Std metric coarse pitch for M10 should be 1.5mm. the hub studs are left hand M10 x 1.
You can get the tap from eBay, Chinese ones are cheap enough and adequate for the job of cleaning up threads. They take abou a week to arrive.
PostPosted: Wed Nov 27, 2019 1:35 pm
by puggie6653
Cheers guys all received and understood
