Slow speed judder
PostPosted: Sun Feb 09, 2020 4:30 pm
by Jim
I've got a judder in the steering when slowing down or pulling away. It's a new engine which I've fitted, just checked internals all soid. The only other thing I've done is tighten up the leg shields, any ideas folks?
Cheers Jim
Re: Slow speed judder
PostPosted: Sun Feb 09, 2020 4:52 pm
by missing lynx
Check your forks aren't loose
PostPosted: Sun Feb 09, 2020 5:28 pm
by ULC Soulagent
missing lynx wrote:Check your forks aren't loose
+1
PostPosted: Sun Feb 09, 2020 11:02 pm
by Kev Fox
Check tyres. I get this when front tyre wears. You can feel and see a difference in height from one tread to the next. Might not be your problem but something to check.
PostPosted: Sun Feb 09, 2020 11:46 pm
by missing lynx
Kev Fox wrote:Check tyres. I get this when front tyre wears. You can feel and see a difference in height from one tread to the next. Might not be your problem but something to check.
Good call I once had a problem with a navigator front tyre the blocks wore unevenly giving a choppy ride
PostPosted: Mon Feb 10, 2020 9:12 am
by Rich Oswald
Conti block tread are well known for this uneven wear.
PostPosted: Mon Feb 10, 2020 10:33 pm
by Jim
Folks I'm pretty sure it's not the front end, however my clutch sprocket has some play, can pull it towards me about 6 mm. Anyone reckon it could be this?
PostPosted: Tue Feb 11, 2020 11:01 am
by ULC Soulagent
That all depends on what clutch type is fitted ;) more info please
PostPosted: Tue Feb 11, 2020 1:43 pm
by Warkton Tornado No.1
Jim wrote:Folks I'm pretty sure it's not the front end, however my clutch sprocket has some play, can pull it towards me about 6 mm. Anyone reckon it could be this?
Six millimetres!
Regardless of whether that is the issue, you should get that fixed before you even start the bike up! I wouldn't even let it out of my garage with only a tenth of that :!:
Seriously, you risk breaking your neck, because even with the renowned Lambretta riders' habit of the 'hovering left hand' pulling the clutch will have no effect if that transmission locks up.
PostPosted: Tue Feb 11, 2020 4:29 pm
by Andyf
with it off the ground, does your rear wheel rotate inline?
PostPosted: Tue Feb 11, 2020 10:55 pm
by Jim
Andyf wrote:with it off the ground, does your rear wheel rotate inline?
Yes no problem
PostPosted: Tue Feb 11, 2020 10:57 pm
by Jim
Six millimetres!
Ok It may not be 6mm, but has got a bit of play
