Vibration at throttling off.
Hi All,
Just came back from a ride out and noticed a vibration through handlebars and frame when throttling off and tick over. Cant really feel it under load. The engine has sounded a bit deeper tone the last time out. I have just re done the timing and can get no less than 21degrees BTDC (the stator has no more movement in it).
Could the vibrations be down to the flywheel or maybe a crank? I did replace the piston and rings (all allowances within tollerance).
Didnt know whether the deeper hollow sounding tone is normal for a standard 150 LiS.
Any advice much appreciated before I start stripping it down again.
Thanks.
Thanks.
