hard to kick start 1963 LI 125
Posted:
Tue May 26, 2020 8:49 am
by kennystag
Hi All,
I have to put my full body weight on the peddle to turn the engine over it is really hard to turn it runs fine when started with no funny noises it has been like that since I have had the LI 3 years any idea to what is going on.
Cheers Stag
Skye
Re: hard to kick start 1963 LI 125
Posted:
Tue May 26, 2020 10:21 am
by Rich Oswald
Is it a standard top end? If so the compression shouldn't be that high. You get higher compression with kits on but if set up right with the correct cylinder head profile and the correct squish then it should be quite usable. It may just that your squish is too small and may need a thicker head gasket. Could be many things really.
Posted:
Tue May 26, 2020 12:22 pm
by dickie
Rich Oswald wrote:Is it a standard top end? If so the compression shouldn't be that high. You get higher compression with kits on but if set up right with the correct cylinder head profile and the correct squish then it should be quite usable. It may just that your squish is too small and may need a thicker head gasket. Could be many things really.
Using LI125 gearbox and standard sprockets with larger capacity but similar exhaust timing makes for a really hard to kick over motor.
Basically, you're trying to do about 50% more work by going to 186 (casa or scootopia) with low exhaust ports. Changing to LI150 box or fitting a 17 tooth sprocket is usually enough to do the trick.
Posted:
Thu May 28, 2020 8:21 am
by HxPaul
I have a Casa 185 with an li 150 gearbox,with 46x16 sprockets and its nearly impossible to kick start.
Posted:
Thu May 28, 2020 8:26 am
by MickYork
Try a diet of Kebabs and donuts...….works for me
Posted:
Thu May 28, 2020 9:46 am
by dickie
HxPaul wrote:I have a Casa 185 with an li 150 gearbox,with 46x16 sprockets and its nearly impossible to kick start.
Have you measured compression ratio?
I've just done 2 scootopia 185s with LI150 boxes and 16 x 46 and they were good.
I think the scootopia is a very close copy of the casa.
Posted:
Fri May 29, 2020 12:42 pm
by Stapsie
I have a Case 185, li125 gearbox, 46 x 17 sprocket and kicks over fairly easy. And I'm only a lightweight.
Posted:
Fri May 29, 2020 1:24 pm
by kennystag
I am a heavy weight and it is murder @ 19 plus stone.
Stag
Skye
Posted:
Fri Jun 05, 2020 7:24 am
by Hammer
I’ve got a similar problem, Casa 185 kit li 150 gearbox on a series 3. It kicks ok but it’s very firm and I am concerned for the kick start shaft which is also an li shaft. I’m considering 3 mods at the moment:
1. Upgrade the kick start shaft to gp.
2. Change front sprocket to 17, although I don’t want to mess with the gearing.
3. Drill a decompression port from the exhaust port to the cylinder. Quite radical but I hear it works well.
Any feedback on these greatly appreciated.
Posted:
Fri Jun 05, 2020 7:34 am
by dickie
I've never had anything to do with the casa 185 kit, but I hear the scootopia 185 is a copy.
Based on that, I'd change the front sprocket to 17. I've done 2 LI150s this way in the last few months and they both go well. They don't feel over-geared at all.
Posted:
Fri Jun 05, 2020 7:39 am
by MickYork
How free is it with plug removed ?
Posted:
Fri Jun 05, 2020 7:41 am
by Hammer
Flicks over easy without the plug.
Posted:
Fri Jun 05, 2020 7:45 am
by Hammer
I’m tempted by the sprocket change as it’s easily reversible. It was the overgearing that concerned me.
Posted:
Sat Jun 06, 2020 8:59 am
by kennystag
Hi All,
I forgot to say it turns over freely with the plug removed.
Stag
Skye
Posted:
Sat Jun 06, 2020 11:29 am
by Warkton Tornado No.1
kennystag wrote:Hi All,
Stag
Skye
Ha
Better late than never.
You're not going to like this Kenny.
You need to strip the top end & measure the cylinder head volume. The compression ratio is almost certainly way too high.
It'll be a good thing to do, getting a reasonable CR & the squish spot on. The 'bowl' in the head will need it's volume checking & some extra volume 'added' by removing some of the alloy with a flap wheel/Dremel type tooling.
Posted:
Sat Jun 06, 2020 9:02 pm
by Andyf
Would a 1mm head gasket work as an alternative?
Posted:
Sun Jun 07, 2020 12:45 am
Andyf wrote:Would a 1mm head gasket work as an alternative?
I've had a PM from Kenny & replied.
I would never use a head gasket. In any case, squish is so important to get right, he may get closer to the desired 1.0 mm with none fitted, but no getting around the CR which is too high & needs correcting.
The engine will be so much better for doing it all correctly.
Posted:
Thu Jun 18, 2020 12:50 am
by vegansydney
Is it a pre-2015 'version 1' Casa 185? Or is it a revised 'version 2' (2015+) Casa 185? The geometric compression ratio of the original V1 heads is 10.8:1 with 1.1mm squish clearance (volume of combustion chamber and squish clearance with piston at TDC is 19ml).
For comparison, does anyone know if compression ratio differs on version 2 of the Casa 185, and how this compares to the Scootopia 185 kits?
