Ser. 2 rear hub
PostPosted: Sun Jun 07, 2020 12:28 pm
by greenfingers
Hi..
I've got a problem with the rear hub on my series 2. Its an innocent hub which I fitted a year or so ago. I do not seem to be able to get rid of a very small amount of 'shift' on the hub though....
Having fitted it and torqued it up to 120 lbs/ft - If I put both hands on the tyre opposite one another at a particular point on the wheel then I can feel the movement (tiny knocking) on the shaft. If I leave the wheel where it is and move my hands around the tyre but still opposite one another - no movement. it seems to taper off away from a given spot.
I checked the shaft and can't sense any movement at all within the bearing. There is also no sign of wear on the oil seal and no sign of damage to the splines on the shaft. And no obvious signs of damage to the cone on the inside or outside surfaces.
To try and resolve the problem I bought a tin of grinding paste and spent literally about 40 minutes on and off to get a good fit in the hub.....but I've done this by hand so could I have caused it to get worse?
This is going to sound a stupid and ignorant question - but surely this isn't right is it? Are the hubs and cones matched as pairs, have they been 'bedded' in already? - they were bought as a complete set. Would this be an MOT fail if it had one still or is a tiny bit of shift acceptable?
Any advice is really appreciated.
Martin
Re: Ser. 2 rear hub
PostPosted: Sun Jun 07, 2020 8:03 pm
by rossclark
Fitting the hub and having a little bit of rock can be a symptom of wear in the bearing at the opposite end of the layshaft.
When was the endplate bearing and race last replaced?
