Jeff t wrote:Just fitted a new layshaft and gearbox 4 speed, I have shimmed up with a 1.9 shim and the gap was less than 0.04 but still spun freely. Ordered a 1.8mm shim assembled everything including the clutch nut and the gap is still only just 0.04 so the feeler gauge just nips up. The box is really free and I can select all gears by hand. So do i buy a 1.7 shim or will this be ok. I know the recommended is 0.07 but read some stuff that says if it’s free then a smaller gap is ok but Instinct tells me to re-shim but thought I’d get other views. Top end is Imola,
Something is amiss if varying the big shims sees no change in axial clearance....
It's almost as if there is only one feeler gauge available.
In any case, 0.04 ( 0.0016") is nearly just half of the recommended minimum. Three thou' (0.003") is the optimum IMHO. Any less & you run the risk of locking up the gearbox & not even your left 'trigger' hand will save you by pulling the clutch
There are one or two old scooter racers that can verify what gearbox lock-up is like.
Gearboxes can take a lot of time & patience to set up. Over time, you may find the need to swap layshafts, gearbox end plates (including the bushes pressed in) & amass dozens of shims, some ground flat again after use, ideally measured up & engraved with sizes to make selection easier.
