Mag housing, to whack or not
After eventually getting the piston and cylinder off, I've moved onto frustration number 2, the notorious mag housing.
Mine is totally stuck. I've repeatedly tried a lot of heat with a blow torch, I've wound the m6 bolts in as tight as I dare and I've tried standing the casing on its end in a drum of diesel for a week, but it won't budge at all and I'll break it if I hit it any harder.
I think I have 2 options, leave it in place, or try to knock the mag housing out with the crankshaft.
Is leaving it in place actually an option? The bearings either side of the crank seem tight and smooth and the seals don't leak, but the con rod has about 2mm of sideways movement if I hold it at the small end.
I'm getting contradicting advice on whether this is acceptable and can be centralised by shimming the small end.
Option 2 is ruin the crank and use it to knock the mag housing off.
I'd rather keep the crank if possible after all the effort saving it.
I've looked at how to knock it out and I'm probably missing something obvious, but I can't see how it can move sideways by hitting the drive side of the crankshaft.
the webs of the crank sit proud of the end of the casing, so hitting it will just move it a couple of millimeters until it hits the casing. See photo.
My big worry in all of this is damaging the casing.
Am I doing something wrong?
20200712_173244 by Dan Barrett, on Flickr
