Series 1 no side light
PostPosted: Tue Aug 04, 2020 7:44 am
by Granty
I have all lights, horn working on old series 1, just no sidelight. Would a dodgey earth just effect the sidelight? Main beam, dip beam, speedo, rear & brake light and horn all work, just this sidelight. I have changed the bulbs but just wondering about the earth.
Thanks Grant.
Re: Series 1 no side light
PostPosted: Thu Aug 06, 2020 5:27 pm
by MK Monty
the sidelight normally is off when the headlight is on, should use the same earth as the headlight. sounds more like a swich problem, you can tab it onto the black, rear light feed so its on when the tail light is on to test it.
PostPosted: Thu Aug 06, 2020 9:39 pm
by Granty
MK Monty wrote:the sidelight normally is off when the headlight is on, should use the same earth as the headlight. sounds more like a swich problem, you can tab it onto the black, rear light feed so its on when the tail light is on to test it.
Good shout -- I think a switch problem right enough, everything else is working as it should -- just want it to be right, the next time the horncast is off I'll make up a wire try and tab it over to the black right enough. Thanks for the 2nd opinion -- G
