The U.K. climate is arguably worse & during winter the authorities regularly salt the roads, rather than legislate that winter tyres be fitted.
Therefore, we encounter a corrosive mixture every year in our usual poorly managed country.
Back in the 70's when scooter tyres were little better than wheelbarrow items, & Lambrettas were an essential, only means of transport, we assembled our wheels with grease. The inner faces of the flanges that bolt together & the areas of the rims that came into contact with the tyre beads were greased up. (Yes! I was a Greaser
) This would then enable far easier assembly & disassembly. Not only that, corrosion was kept @ bay.
There was never any trouble with the tyres or inner tubes deteriorating & the inner tubes stayed in place (they have a far greater contact area with the tyre than the rims)
If I were in your scenario, I would have no hesitation in greasing up the rims. 'Rubber' grease (as used in car brake assemblies for years) might be an added touch of sophistication as a nod to those horrified @ the thought of grease in contact with 'rubber' or nitrile, but I cannot be the only elder scooterist that carried out this common practice
The alternative is to create a liner from a cut up inner tube, as used in recent times by some racers. It was supposed to reduce the incidence of punctures, but, personally, I don't see how.......
