Rear Sprint Rack
Posted:
Sat Jan 30, 2021 2:30 pm
by Specialcase
Hi all - I’m thinking of putting a sprint rack on my LiS but have seen so many variants I don’t want to regret buying and fitting the “wrong un”.
I’ve seen ones with 4 screw fitting and some with two parallel bars that screw onto the frame these I feel will ‘do more damage’on my newly painted frame? Also some have an upright on the back and some on the front of the carriers, also some have side up-stands. I don’t have an Ancilotti type seat so don’t need a cutaway style.
Anyone have any experiences/issues with any particular type?
SplC
Re: Rear Sprint Rack
Posted:
Sat Jan 30, 2021 4:25 pm
by Warkton Tornado No.1
I fully understand & agree with your concern.
I think I have a couple of old sprint racks in the garage rafters & the oldest was manufactured using four threaded pillars that align with the frame holes. To my mind, that is the best type as any effect of mounting it is minimal as far as the frame/paintwork is concerned.
Whether that method of manufacture still exists today, I don't know. But it did, 'back in the day'......when you could leave your front door unlocked & Fred Perry's had four buttons......
Posted:
Fri Feb 05, 2021 3:57 pm
by burnside
You need to ask yourself what do you need the rack for, is it form or function, do you do rallies and need to carry a lot of gear, do you want/need to carry a spare wheel on the back or not, do you ride with a pillion and they want a backrest, etc.
Posted:
Fri Feb 05, 2021 10:47 pm
by Atb Tim
I used the large type sprint rack with the parallel bars. Just fitted rubber washers under the fixing holes on the bars which left no damage after removing it.
Posted:
Sat Feb 06, 2021 9:30 am
by Knowledge
I prefer to use nylon washers in these circumstances as the do not deform like rubber washers.
Posted:
Sat Feb 06, 2021 5:39 pm
by ToBoldlyGo
Must admit I've taken all my sprint racks off now. I never used the bloody things. So it was definitely form over function in my case. But when I did I just used tap washers underneath.
Posted:
Mon Feb 08, 2021 12:38 pm
by jonw
Atb Tim wrote:I used the large type sprint rack with the parallel bars. Just fitted rubber washers under the fixing holes on the bars which left no damage after removing it.
+1 works a treat!
Posted:
Fri Feb 12, 2021 4:50 pm
by corrado
It's worth investing a fiver in a 300mm x 300mm x 4mm thick sheet of rubber for many useful Lambretta applications. Couple of strips for the sprint rack with the 2 parallel bars. I made 4 plates to sit under the 2 seat catches (for 2 seats), and some smaller pieces for the CDI & regulator holder (to stop vibration).
First one I looked at. Cheaper ones may be available .......
https://www.ebay.co.uk/itm/Rubber-Sheet ... xyVLNS8gQC
Posted:
Fri Feb 12, 2021 9:26 pm
by citydaz
corrado wrote:It's worth investing a fiver in a 300mm x 300mm x 4mm thick sheet of rubber for many useful Lambretta applications. Couple of strips for the sprint rack with the 2 parallel bars. I made 4 plates to sit under the 2 seat catches (for 2 seats), and some smaller pieces for the CDI & regulator holder (to stop vibration).
+1 useful in many different applications, reducing vibrations, aligning different levels, protecting paintwork, etc etc etc
Posted:
Sun Feb 28, 2021 5:09 pm
by corrado
citydaz wrote:+1 useful in many different applications, reducing vibrations, aligning different levels, protecting paintwork, etc etc etc
Yes, one well know dealer sells them to fit under CDI & regulators to soften vibration and prolong the life.
Posted:
Thu Mar 04, 2021 10:33 pm
by citydaz
corrado wrote:citydaz wrote:+1 useful in many different applications, reducing vibrations, aligning different levels, protecting paintwork, etc etc etc
Thats a job for the week-end then!
Posted:
Sun Mar 07, 2021 7:28 pm
by Specialcase
Thanks for your input got myself a standard sprint jobby. As soon as my scoot LiS MB RT is painted I’ll get a few pics... y’know before, during and never finished!
