Scootopia clubman
Posted:
Sun Mar 28, 2021 7:32 pm
by steveg
I need to replace an early version BGM on a S2 with a 186 mugello and 26mm PHBH.
I'm thinking of trying the Scootopia 42mm clubman, anyone got experience of these? Would you recommend?
Cheers Steve
Re: Scootopia clubman
Posted:
Sun Mar 28, 2021 8:34 pm
by Toddy
Fitted a few on mugellos good quality and fit and performance is good on the ones I’ve fitted
Posted:
Sun Mar 28, 2021 11:04 pm
by Scooterslag
I fitted one to a mates Jet 200 and went well with a up-jet on the standard 20mm delly . Nice fit and quality for the money .
Posted:
Mon Mar 29, 2021 8:44 am
by Tractorman
Very good exhausts and they fit without the fettling that comes with many other makes.
Posted:
Mon Mar 29, 2021 2:18 pm
by ULC Soulagent
Great pipe and value for the money. Finding a dealer who has them in stock is the problem
Posted:
Mon Mar 29, 2021 5:46 pm
by hullygully
I fitted one onto a mates SX150, fitted like a glove
Posted:
Mon Mar 29, 2021 7:55 pm
by steveg
Performance wise are they more AF or BGM?
Posted:
Mon Mar 29, 2021 10:21 pm
by Toddy
steveg wrote:Performance wise are they more AF or BGM?
On the ones I did it compared performance wise more with the BGM
Posted:
Tue Mar 30, 2021 6:40 am
by steveg
Toddy wrote:steveg wrote:Performance wise are they more AF or BGM?
Sounds good
Posted:
Tue Mar 30, 2021 9:34 am
by landybretta
ULC Soulagent wrote:Great pipe and value for the money. Finding a dealer who has them in stock is the problem
Scootopia website says out of stock but i have just ordered one from their fleapay shop.
TASS also appear to have them.
Posted:
Tue Mar 30, 2021 11:19 am
by dickie
I've never had a scootopia on the dyno, but I did with an ancillotti which it is copied from. I changed the ancillotti to a bgm clubman, but notably, also went from 25phbl to 30phbh at the same time, so not a direct comparison. Power went from 9.5bhp to 13bhp. Lost a little bottom end and felt slightly more top-endy, as if it were a very low end expansion.
The scootopia is a 42mm header and the bgm 48mm. Larger headers tend to work better at higher rpms, all things being equal.
Posted:
Thu Apr 01, 2021 5:54 pm
by ToBoldlyGo
Get one. I doubt you'll regret it.
Posted:
Thu Apr 01, 2021 9:10 pm
by steveg
Thanks to everyone for the feedback.
Largely very positive and I have bought one off their Ebay shop.
Should be here tomorrow I hope.
Will also have the BGM repaired, only the baffle plate come away but always nice to get something new.
Posted:
Sun Apr 04, 2021 10:26 pm
by steveg
Picked up the scootopia pipe Friday.
First impressions prior to fitting, feels a little lightweight, particularly compared to the BGM pipes, paint finish not great (will blow over with VHT paint) welding around manifold stub not good, possibly even porous, so a friend is going to grind it back and reweld. On the plus side it comes with everything there to fit it (gasket, spring puller etc) which not all pipes do.
Hopefully it will fit well and performance will be decent enough.
